Hi All,
Just got the Plextor PX-716A - it replaced my old pioneer 4X dvd-r burner.
Firmware is 1.02 the latest. Did not have to flash it, that was the firmware.
Using Nero 5.5.9 with update patch, Also Roxio 7 that came with it.
Using 8X rated DVD-r media from Sony -japan made
Memorex 8X - Tiawan made
Burn speed is 8x but for the first two or three minutes the burner is at lead and it seems to be testing the media or something, this adds total burn time of a full dvd-r to about 15 minutes.
Both Nero and Roxio do this with both medias, not sure why but I am thinking that the firmware is the issue. Running Windows XP Pro and had no issues with my old pioneer 4x dvd burner. Also, had about three coasters with burner so far.
Thinking of returning this, I have read on the forum here about hardware problems. I am not impressed with this plextor.
Any ideas???
Make sure that you have DMA enable. The slow buring speed could be the result of having PIO only. If you don't know how to check this ... check this ==>
start ==> settings ==> control panel ==> system ==> hardware ==> device manager ==> IDE ATA/ATAPI Controllers
Check both your Primary and Secondary IDE channels (properties ==> advance setting) to make sure that the Transfer mode is "DMA if available". -
Yeah I went through that but is this a new thing all of a sudden?
for me after much checking, I found out my bios listed my writer as none, so I changed it to AUTO & it was fine. -
) that my drive was set to PIO only. But then the burning process was about 40 minutes...
15 Minutes is IMHO impossible without DMA enabled. -
Usually, when the drive is not in DMA mode, you'd see the drive buffer empty and re-fill itself several times and the drive light would blink off momentarily. At 8x, you should expect a burn time around 12 min., 15 isn't so bad.
More likely, what's happening the drive is slowing down during the burn. This is normal and happens with media that is not recommended for the drive. You should go to Plextor's site and download the recommended media list for your drive. -
Originally Posted by boraxOriginally Posted by nic2k4
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 17:01 -
Best avi to dvd software that burns
By mol3000 in forum Video ConversionReplies: 1Last Post: 18th Aug 2010, 23:19 -
Keep getting bad DVD burns after OS reinstall
By brassplyer in forum ComputerReplies: 18Last Post: 20th Sep 2009, 01:12 -
DvD R9 burns disks ok but cant read them
By craftycelt in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2008, 17:56 -
Plextor 810SA Burnning DVD 9 Disc
By wagswvu in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 10:33
