Results 1 to 11 of 11
  1. I encoded a 320x240 avi at 2250 kbps to mpeg-2 with TMPGEnc and got a 9.68 MB final file size. I changed the resolution to 160x120 leaving the bitrate at 2250 kbps in TMPGEnc and suprisingly this setting also yielded a final mpeg-2 file size of exactly 9.68 MB. I then tried lowering the bitrate and still ended up with a 9.68 MB file size. I changed the settings in System/System Stream/Type to various settings, including mpeg-1 non standard, and still always ended up at a 9.68 MB final file size.
    Obviously all my setting changes are being done without reliance on the "wizard" feature.
    Why is the final file size not changing when I change the resolution and bitrate parameters in TMPGEnc?
    Thanks.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Could it be the audio??? Is it vbr or cbr??? Is it pcm?? If it's uncompressed it will remain huge! Ac3 and mp2 can be changed from 92 to 384 (maybe lower and higher depending on the application - 448 is the highest I believe).
    Try changing the audio bitrate as well to lower file size
    Kevin
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Changing the resolution won't change the file size .... ever. It's all about bitrate. Try setting the System Stream Type to MPEG-1 System(automatic) while lowering the bitrate.
    If in doubt, Google it.
  4. Jim,
    Would you please explain why changing the resolution doesn't affect the final file size.
    Thanks.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Because the size calculation is as follows:
    size = running time X bitrate
    Your encoder will still allocate the same number of bits per frame (the number of which you specify by what you set your bitrate to), regardless of what resolution you use.
  6. Member vhelp's Avatar
    Mar 2001
    New York
    I think that the confusion is with the "resolution" difference, that this
    is always confusing to most peoples.
    .. I think that some time ago, someone came out with a pixel-for-pixel
    .. calculation count - something like (ie, 300,000 per frame *times* fps, or
    .. something like that) But it was nice to see such info/stats
    Anyways.
    *** size = Running time X Bitrate
    I did a small test encode of 100 frames (again.., I seem to just love doing
    nothing better than test test test) anyways..
    MPEG-2 w/ CBR 9000 bitrate encode:
    ** 352 x 480 .. 2,569 kb
    ** 720 x 480 .. 2,891 kb
    With a difference of 322 kb's. I would guess, that onces you factor this
    into the info (see above request) the pixel-to-pixel numbers will add up
    coensidentaly.
    But, the above 322 kb difference makes sense because you have a different
    size container (or more (or lesser) cubes to fill)
    But this ratio should always be the same when talking about the formula:
    -vhelp 2972
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    coensidentaly.
    Not to discount what you're saying, and I know that this test is only anecdotal, but IMO 100 frames isn't a big enough test sample, and quite frankly I'm very surprised that there's a 322KB difference over a sample that's less than 4 seconds long. One only has to extrapolate that to the average film length of 90 minutes (161870 frames @ 29.976 NTSC) to work out that there would be a 509MB difference between Half D1 and Full D1 should the pattern as displayed in the test sample be continued, which fully highlights the fragility of such a small test sample.
  8. Member vhelp's Avatar
    Mar 2001
    New York
    Opps
    My mistake. After double-checking, I found that I had the encoding mode
    set to CQ
    -vhelp
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Opps
    set to CQ
    Those figures look much more possible now ...
  10. Member vhelp's Avatar
    Mar 2001
    New York
    Alright.. alright
    I re-did the test (by now, you know I love tests)
    I did a small test encode of 1829 frames (1 minute) ..
    ** 352 x 480 .. 69,385 kb
    ** 720 x 480 .. 69,387 kb
    With a difference of 2 kb's.
    ( ..that better now ? )
    -vhelp
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Alright.. alright
    sounds good !
