In the past ive always used tmpg dvd author to author, but with the larger options i decided to use dvd lab pro. My question is, say that i have 2 or 3 svcds same film but 2 or 3 discs, how do i author them in dvd lab pro so the film will play continuasly, this is easy in dvd author but i cant figure it out in dvd lab, any help much appreciated.![]()
Import each as a seperate movie. Use the connection window to ensure it plays from the end of one to the beginning of the other.
There are 10 kinds of people in this world. Those that understand binary... -
If it's the same film why don'y you join all .mpgs in one and then demux and import in dvd la pro?That's what i do...
I just wrote a small guide on this. Link below.
Cheers, Jim
My DVDLab Guides
how can I use .SUP files with DVD Lab Pro
By taasan in forum SubtitleReplies: 23Last Post: 7th Jan 2013, 07:09 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 15:02 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 08:56 -
DVD Authoring with DVD LAB PRO doesnt create all files
By SSJ4Thiran in forum Authoring (DVD)Replies: 16Last Post: 18th Feb 2008, 10:03 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 19:28
