2.0 Beta 8 - Released 05 Jan 2005
Changes:
- Fixed a PAL->NTSC bug when AC3 audio is selected in the settings.
- Added PAL->NTSC conversion for AVI (Xvid/DivX) sources.
- Added PAL->NTSC conversion for VCD sources.
- Added AVI to DVD encoding using SVCD resolution (smaller files)
- Added an enhanced AVI to DVD-SVCD option for Widescreen TVs.
- Several other bug fixes.
Results 1 to 20 of 20
Suggestion:
Can you automate on whether a file needs 44.1 -> 48 khz conversion? It seems like you should be able to automate this by determining whether the file is already 48k or not.
glad i bought the program -
If the source is 48Khz then no audio conversion takes place. The file still needs Nav Packs however...
when converting AVI files does the sound still always output as AC3, or can you choose between AC3 and MP" Now?
it does currently. I shall make sure it follows the global settings.
will pan and scan be included in future betas, really need this feature before i use it more. Beta 7 was great
when I download the registered users beta 2 am I getting the latest beta release? or do I have to download the demo version for the latest beta?
Registered users beta 2 is always the latest. Currently it is BETA 8.
Thanks for the software.
I am a registered user and am also eagerly awaiting the pan and scan feature in the beta as my main player is a five disc Pioneer. Any news as to when this feature will be activated.
Thanks again. -
I always get these errors first it does this:
application has generated an exception that could not be handled.
process id=0x938 (2360), thread id=09b0 (2480).
Then this:
Type: System.NullReferenceException
Source: Interop.CodeLock
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at CodeLock._Secure.Authenticate(String pass)
at AxCodeLock.AxSecure.Authenticate(String pass)
at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
What does it all mean looks like some big math formula to me arghh .. -
rodrx: Can you try re-installing?
boggle: Not currently. I don't see the advantage of it being bigger than it is....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Just installed Beta 8 but when i click on the football icon up pops the registration machine with all the info in the User Data,Name & Registration code no problems but when i click on register the box dissaperes and thats it ?.
Not had any problems in the past with registering. -
Drop me an email. We can do it manually.
E-mail sent but whilst waiting for a reply i removed the programe again and re-installed it and for some reason this time it worked.
Thanks. -
Ok. (back from watching the football now) Let me know if it requires further attention.
I have it working in the build which is in progress. Thus it will be in the next release which may well be RC1....Originally Posted by vern_ulvenSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Can it convert ntfs to pal?
I know it does pal to ntfs but can it do it the other way? -
It could but doesn't at the moment. 100% of people wishing a TV standard conversion have wanted pall to ntsc.
DVDFab Media Player 1.0.0.1 beta has been released
By Kerry56 in forum Software PlayingReplies: 3Last Post: 13th Feb 2014, 04:00 -
New HCenc beta released
By hank315 in forum Video ConversionReplies: 4Last Post: 22nd Sep 2009, 18:36 -
New beta of HCenc 0.24 has been released.
By freebird73717 in forum Newbie / General discussionsReplies: 1Last Post: 18th May 2009, 03:00 -
hank315 has released a beta version of HCenc 024
By freebird73717 in forum Newbie / General discussionsReplies: 0Last Post: 31st Dec 2008, 11:20 -
Beta? what is it
By Stephanee in forum ComputerReplies: 3Last Post: 5th Nov 2008, 10:58
