I have lots of video files on my hard drive, which I would like to make a list of (including things like what codec...mpeg1, mpeg2, avi, etc...resolution, ratio, audio codec, etc)...it would be handy if you could call this program for a group of files or a folder and have it output the results to a tab delimited text file.
How difficult would something like that be to write? Don't need any of the fancy stuff (like the preview), but the other window (where the info is) looks like just the place to start.
Does AVICodec already do this?
YES! It does! I was not aware of this program. Had been using a prog called GSpot Codec Appliance, which only supports avi files (no jokes about the proggie name please).
This program does everything I need and then some...only thing it doesn't do is handle/give info on LPCM audio streams (which a lot of dvds & dvdrips are encoded with).
Thank you for pointing me at exactly the tool I needed! -
WMV Modification Without Reencode
By frmys in forum Video ConversionReplies: 4Last Post: 1st Sep 2011, 06:24 -
Program to identify video details
By mikemar in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2009, 15:51 -
Any chance for a spell check modification or code snippet?
By G)-(OST in forum FeedbackReplies: 22Last Post: 7th Jun 2009, 01:41 -
Flash -> H.264 Conversion Application or Modification Wanted
By dexgarvey in forum Video Streaming DownloadingReplies: 2Last Post: 10th Dec 2008, 17:48 -
Anybody have any experience w/ Child Support / Modification???
By makntraks in forum Off topicReplies: 18Last Post: 27th Feb 2008, 12:44
