Hello. I am having some issues configuring WinDVR. I just installed my new Hauppauge PVR-150 and WinDVR. The software picked up the video input instantly and it looks good (not great, but I will tweak that later) my issue is with the sound; there is none. I have tried the settings many different ways and I cannot get it to work. I only have the soundcard on my MB and it is fairly old. I am using a P3 833 running win2k. I have an inkling that the issue may have to do with audio drivers as the intervideo site says this is a system requirement...
http://www.intervideo.com/jsp/WinDVR.jsp?mode=Requirements
Could one of you wise folks enlighten me? What is WDM? Is is required? Where can I get it? How do I install it? Thanks in advance.
rocksoup
Stop right there! Don't do anything else! Remove that WinDVR program, because that's a WDM program. You just got a Hardware MPEG2 Encoder card, why would you use a program designed more for WDM capture cards that uses WDM Video Capture Driver and WDM Audio Capture Driver.
I have the same card you have, but I use GB-PVR and turns your PC into a HTPC. What is HTPC, Home Theater Personal Computer. GB-PVR is freeware and can be found on www.gbpvr.com, where I am daily. Stop by and check the program.
One other note, the WinTV PVR-150 can be used with Media MVP 1000 also from the same manufacturer. With MVP, GB-PVR and PVR-150 you can watch LiVE TV, record and do a lot of things on both the PC and your home living TV by using MVP 1000.
Just to let also know that the WinDVR if you still want to use it, is very buggy. I use to use it and the WinDVD Recorder Platinum on a WDM Capture card.
Right now since you just got your PVR-150, it's still running in the default mode for sharpness and detail this around 3. With a registry tweak you can set it to the MAX. There is a program that will do that for you also on another site.
See you on GBPVR site...
Best Regards,
Tipstir
MediaMVP Supporter
Hauppauge hd pvr sound issues with new graphics card
By Mitterhouse in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2011, 18:26 -
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 14:47 -
PVR-150 poor tv quality
By kaptwan in forum Capturing and VCRReplies: 3Last Post: 21st Aug 2008, 16:15 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum Capturing and VCRReplies: 11Last Post: 14th Mar 2008, 11:03
