I have purchased these Tiayo Yuden discs that are 8x. It states on the container that these are not suitable for drives that do not burn at this rate. Is don't have y computer handy so I can't test this out, but will I get an incomplete transfer of data if I use this in my 867 mhz PB? I was of the understanding that I could burn discs on my Mtushita drive even if they are of a speed higher than that at which the drive burns. It's so hard to find discs that burn at my drive's slow rate that they are alomost always at least 4x discs.
I have until now been going with Ritek RiData discs. This is my frst step into Taio Yuden's territory as well as 8x discs. Please tell me I haven't wasted my money in these.
Thank you,
tab
same here... still have an A03 drive which burns most 2x and all 4x DVD-R at 1x. Of what I have heard and read and understand these 8x Taiyo don't burn at 1x, but I could be wrong.Originally Posted by tab75-13
Anyway I got fed up of burning at 1x and have ordered a new internal burner (Lite-On SOHW 1635S). -
so it looks I wasted my money on these. Can you point me to any sources please f you recall where you read this.Of what I have heard and read and understand these 8x Taiyo don't burn at 1x, but I c ould be wrong
Thanks,
[/quote] -
[quote="tab75-13"]
from the media information from this siteCan you point me to any sources please f you recall where you read this.
http://www.os-mediatrade.de/product_info.php?cPath=80_5_32&products_id=226&osCsid=de3c...db2d63974e523a
but I also found another forum thread where the media information states 1x
http://www.abxzone.com/forums/archive/index.php/t-84094.html
you may try...
cheers -
Ok thank you for that. But I was just reading on this Apple site that if your computer is equipped with a superdrive and the vendor is someone other than Pioneer, it should already be compatible with the faster media. My PB 12" is equipped with a super drive and the vendor is Mtushita (sp?) It's a Mitushita 815 J I recall, again as I don't have the compuetr on hand because it's gone to see the dr.
Apple also provides updates for the superdrives for these computers that may not be currently compatible with the newer faster media.
http://www.apple.com/hardware/superdrive/
having read this page, it seems my PB or maybe even your computer with its superdrive may be compatible with the newer drive or is just an update away from being so. HAving read this page, I am sitting a tiny bit easier, but again, I'll go an check to see what the links that you've shown me here have to say.
Thank you for the help,
tab
on the same page for its computers -
yes this is the famous update for the earlier pioneer superdrives. it allows to burn to faster than 2x media but faster than 2x media will only be burnt at 1x...I'm getting rather nervous when I have to burn more than one DVD-R at 1x so I prefer to pay the 70€ for the Lite-On and I hope it will work with my Quicksilver (theoretically it should...)Originally Posted by tab75-13
cheers
Taiyo Yuden DVD-R's (In Australia)
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 20th Jun 2011, 04:21 -
Taiyo Yuden (That's) Triple Guard DVD-R
By piano632 in forum MediaReplies: 16Last Post: 22nd Oct 2009, 17:37 -
Taiyo Yuden DVD -- are these shiny?
By lordsmurf in forum MediaReplies: 10Last Post: 21st Jan 2009, 14:45 -
Question about Taiyo Yuden DVD-R discs
By BrokenOne in forum MediaReplies: 37Last Post: 23rd Feb 2008, 14:32 -
Taiyo Yuden DVD-R - Thanks
By casual-dvduser in forum MediaReplies: 3Last Post: 6th Jun 2007, 03:59
