i burned some files i had on my computer to a dvd to play on my dvd player to watch on my tv and when i put the disk in my dvd it played but it did not have any color but when i put it in my computer to watch it had color whats wrong with this picture?
Results 1 to 30 of 35
i am in dallas texas the southern region.I also changed it to pal when i made the dvd. Can this still be fixed?
This happened to me, and I almost went insane trying to figure out what happened, then I realized that I had broken one of the pins in my s-video cable ...
(so what I'm asking is, is it only that dvd that's in black and white?)-Yar, matey!- -
You dont want to change it to Pal,You want NTSC.Originally Posted by dwayne00
From the glosary on the left<<<
PAL
Short for Phase Alternating Line, the dominant television standard in Europe. The United States uses a different standard, NTSC. PAL delivers 625 lines at 50 fields (half-frames interlaced) per second. The resolution of a PAL VCD is 352x288 pixels, a PAL SVCD is 480x576, and a PAL full D1 DVD is 704 or 720 x 576.
NTSC
Abbreviation of National Television Standards Committee. The NTSC is responsible for setting television and video standards in the United States (in Europe and other parts of the world, the dominant television standards are PAL and SECAM). The NTSC standard for television defines a composite video signal with a refresh rate of 60 fields (half-frames interlaced) per second. Each frame contains 525 lines and can contain 16 million different colors. The resolution of an NTSC VCD is 352x240 pixels, an NTSC SVCD is 480x480, and an NTSC full D1 DVD is 704 or 720 x 480. -
oh yeah its just that dvd i played another dvd in my player and it was in color and the screen that comes up when you first turn your dvd on without a dvd in it the screen will be in color. Then when i put the dvd in it goes to black and white.
A Pal DVD will be Black and White ,if your Player Is not Region free and have a Pal to NTSC converter,Or Even somtimes the TV it self will not convert it.I'm not to sure of all the in's and out's.But you do want NTSC.
Can i copy the disc using ntsc and will i be able to have color then or is it something i can do to my dvd player which one of these would be the best option or do you know something better to do?
yes and my dvd plyer is an oritron its one of the first dvd players made when they first came out.Originally Posted by canadateck
Whats the model Number? You can see if there is a hack so you can play the Pal DVD,Because trying to convert Pal to NTSC will not be easy.For some it is.But i think you should see first about the Hack.
Here...there is more in the list if this one doesnt work.
TO CHANGE REGION TO "ALL"
Set player with "NO DISC"
press "MENU" key
press "9" key
press "TRAY OPEN" key
press "5" key
press "MUTE" key
press "OK" key
press "EXIT" key -
Ok heres the link to the other hacks try them,one Might work,But like i said it could be the TV aswell.Mine can play Pal,but some cant.
https://www.videohelp.com/dvdhacks.php?select=Oritron+DVD200 -
If you cant get a hack to work,read lots of whats here.
www.videohelp.com/forum/viewtopic.php?t=160433 -
I would try everything to be honest..Trial and error, You never know...
none worked should i just copy the disc and make sure that its set to ntsc or i have another dvd player it is apex but it doesnt even load or recognize the disc when i put it in.
Apex may have a hack to.
If you let Nero convert to NTSC ,it wont be very good. Read up on the link i posted.
Edit: If you are using Nero , even any-other all in-one. -
Color on the computer, then black & white on a settop & TV is a classical sign that you have an NTSC-only TV.
Either reconvert your source to NTSC (guides here), or buy a multisystem TV.
Further info:
https://www.videohelp.com/forum/viewtopic.php?t=248757If in doubt, Google it. -
how can i convert my dvd.I tried to open the files from my dvd and it wouldnt open let alone find it.Originally Posted by jimmalenko
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 10:06 -
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 09:04 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 08:53 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Feb 2009, 22:16 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 15:58
