hi ive read threw tons of posts and am still none the wiser
so this is what im trying to achieve......
i have some cartoon files that ive downloaded there recorded from tv somewhere these file types are...(v codec)-xvid mpeg4
(A.1 ) mpeg layer 3 ????
i want to burn these to dvd-r prob is i dont have a dvd burner on laptop just a dvd recorder under my tv so i need to tranfere these file to my dv camcorder first
software i got to use is,,,ulead moviestudio 8
riverpast movie cleaner
virtualdub
panasonic dv codec
AVIcodec,divx codec
jvc gr-dx100 dv camera
win xp sp1
so i load these files into moviestudio dont do no editing just click the make movie button which then comes up with option to send to dv cam
so then it starts to render the file turns into a 2+gb avi file
then when all tha rendering is done i hook my camcorder up to laptop via firewire it tranfers fine except for the sound,,there no sound at all
ive tried to find a soloution but the forums seem to be confusing me even more
is there anyone out there kind enough to give me some much needed advice a step by step would be great!!!!!
is there a better way off doing this whole process
thanks for reading ppl
Results 1 to 11 of 11
I don' know the exact answer but I do know one thing - you need to isolate where the problem is occuring. Check our audio and video after each step of the process to see where it's being lost. My guess would be in the encoding from mpeg4 to DV - so check the DVAvi file before transferring to the camcorder.
What file type is the original audio? You can use gspot to check this. What is it AFTER you encode to DV ? What are the video codecs of the original and the converted DV file?
Have you tried to save it as AVI in VDubMod? That might work but I've never done it with this file type. With the info I discussed here, I would expect someone here can figure it out fairly quickly. -
Cant you just Play and record right into your Cam? Then Transfer to the recorder,Or stright into Dv input onto recorder?
is it even possible to do what im trying
as in download small clips off net onto pc,,, pump into dv cam (somehow)
so i can hook cam up to tv to record threw my dvd recorder,,,,,
thanks,,,,the audio is all fine up untill it goes into camits while its being tranferd threw the firewire that the sound is going missing
How do you get your Video from your Cam to your DVD Recorder?all you need to do is play the file to the Cam then transfer to the recorder.
i use ulead moviestudio 8 i import my video file and click make movieit then asks where i wanna put this movie so i click dv camera i then have to create a video file of my movie before i can access the export function i dont think its possible to play and render and record on the fly in ulead 8 can anyone suggest a good editing software cause ulead im not sure wether its all good
ok when ulead is finished doing its things it turns the file into
File : 12.81 MB (12.81 MB), duration: 0:00:03, type: AVI, 1 audio stream(s), quality: 90 %
Video : 12.22 MB, 34157 Kbps, 25.0 fps, 720*576 (4:3), dvsd = Sony Digital Video, Supported
and audio is.....
Audio : 562 KB, 1536 Kbps, 48000 Hz, 2 channels, 0x1 = PCM, Supported
also what is this real player preview can u explain a bi more to me
c heers
My Laptop not recognising my JVC DV Camcorder
By topcat0001 in forum Capturing and VCRReplies: 7Last Post: 29th Aug 2010, 11:42 -
My Laptop not recognising my camcorder via firewire ?
By topcat0001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Aug 2010, 11:27 -
Hookin Mini DV Camcorder To Laptop
By Tribizvid in forum Video ConversionReplies: 2Last Post: 7th Feb 2010, 22:27 -
camcorder discs to laptop
By revid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Mar 2008, 13:01 -
tranfering files from PC to PC?
By yogart in forum ComputerReplies: 16Last Post: 2nd Jun 2007, 15:46
