Helo Guys
I have a small problem now, but dont know how to fix
Yes, first, i have an avi file, with 23.576 frame per second, 2 sound channels, everything is oke
BUT , when i use Mainconcept or Tmpenc to convert it to DVD , i think everything will be oke, yes, but he he, the sound is out of sync
Because, mainconcept and tmpenc only allow me to convert the avi file to framerate 24,25,29.97 only( , with both PAL and NTSC system .
And that's why,its make my sound is out of sync .
Lolz, and now, i dont know how to do ?
How can i convert my avi file from 23.576 frame rate to 25 with sound sync ?
Thanks for any help ^^
Results 1 to 30 of 31
in both -- its supposed to be 23.976 progressive and add pulldown ..
try it -- it works ..
but if source is 23.576 really .. you will have to change its speed to the correct ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks thanks, it was a typo, my source file = 23.976 frame/s
But how can i do this :
"in both -- its supposed to be 23.976 progressive and add pulldown" .
In Mainconcept ?
And its will fix my sound sync ?
THanks -
https://www.videohelp.com/forum/viewtopic.php?t=252034
Check out that thread. MainConcept may have a pulldown option too, I don't know. But TMPGenc can definitely do it during encoding and pulldown.exe can always be used after encoding. -
In Mainconcept mpeg encoder, click Details, Advanced, Multiplexer Settings. Adjust pulldown.
Cheers, Jim
My DVDLab Guides -
hmm - not quite ..
Main concept adds pulldown when you set source as progressive 23.976 from the drop down and have already selected dvd profile -- go to the next tab and you will see 3:2 listed and greyed out as it is pre selected for you .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks guys, but i can only use Tmpenc plus to encode my movie only without sound out of sync
With Mainconcept, i can select 23.976 frame rate NTSC in Detail/setting BUT seem to be its not work !! Because when i push the advanced tab again, the setting is back to 29.97 frame rate not with 23.976(
How can i do this in Mainconcept -
Select mpeg2 as your Output type.
You can then select any fps.Cheers, Jim
My DVDLab Guides -
Originally Posted by reboot
I tried DVD and MPEG2 output but the output file still has sound sync problem, and i dont know why, of course i chose 29.997 drop framerate NTSC(
Originally Posted by canadateck
adam -- in MC , when you select 29.97 as target and set source to 23.976 .. it automatically adds pulldown for you --
it is still encoding progressive ...
that is - if you use the dvd profile"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I was just talking about encoding in NTSCfilm vs NTSC in general. I've never used MainConcept.
Originally Posted by adam
but, as BJ_M said, ifyou tell mainconcept the source is 23.976 and the destination is dvd, it should encode w/o unsyncing. -
Originally Posted by BJ_M
Yes, i chose DVD profile and MPEG2 profile but the output file always out of sync !
my source = 23.976 and when i open my file with MC , and select NTSC system, its wont let me chose some options but i tried with NTC 29.97 frame drop down for ntsc movie , but its sucky !
How can i do -
you can select generic mpeg2 to unlock settings .... but thats not his problem -- his sound is out of sync which is a problem that is hard to pin down with out knowing a lot more facts ..
Hello guys ^^
First, i dont know how to create NEW profile in Mainconcept .
Second, when i chose MPEG profile in Mainconcept, i CANT select the option NTSC Film rate pulldown
And my source file = avi = 23.976 frame/second ! -
din4na
Can you give us more info on what kind of audio is in the avi file? If it a AC3 or VBR. that may be the problem.It doesn't matter who you vote for. The government always gets in. -
Hi again guys, my when i open my avi file with virtual dub, the program report that my file has invalid ABR sound stream .... -2 channels
In most of the case, i alway decode it with virtualdub mode to *.ac3 file, or use virtual dub to reencode the sound to 2 channel VBR and its work great , because most of my avi file has frame = 25.000 and when i convert it to dvd compliant , its good . But this time, avi file = 23,976
Does this help ^^
Thanks for any help .
Ps: I tried to decode it with virtual dub mod, but the sound still out of sync because the frame rate issue -
what your problem is is that when u encode mainconcept is changing the source fps from 23.976 to 25. So the video's going faster than the audio. What you need to do is either frameserve from AVISynth to BeSweet or decompress to a WAV (which will be quite large btw) and then recompress to either MP2 or AC3. I recommend AC3, but in PAL land you can go either way.
din4na,
I was having the same problem as you using Mainconcept Encoder but I just solved it.
BJ_M hit upon it in about the second reply in this thread when he said it is supposed to be "23.976 progressive and add pulldown" but the way Mainconcept works isn't obvious.
Everytime you select NTSC and MPEG2 it defaults to 29.97 on the front page and not the 23.976 you want. When you go into the Details and Advanced tabs to try to alter the framerate and apply the pulldown the pulldown is greyed out and changes made to the framerate are forgotten when you get back to the front page. It was bugging the hell out of me.
But I found that all you have to do, before you alter the framerate under the Details tab is to change the Field Encoding tab to Progressive first before making any other changes. It defaults to Bottom Field first and this is what is screwing things up.
Now you can change your framerate to 23.976 and then click through to the advanced tab and the pulldown box is selectable. Change it to 3:2 and job done.
I selected Elementary Video from the front screen so that I just got the video encoded and then used FFMPEGGUI to make the audio track.
Opened up TMPGENC DVD Author, dropped the video file and then the audio file into the project and then Begin Output.
Burnt the project to a disc and then popped into my multi-region player and audio and video was perfectly sync'd and no jerky video.
Job done.
Hope this helps you or somebody else banging their newbie head against Mainconcept's wall like I was!
JA -
Thanks alots JA , but i want do everything in Mainconcept but not with 2nd program
Because, if i use Tmpenc plus to encode my avi file , its work very good , i chose elementary options for my file , and no audio/video sync with my file .
But , with Mainconcept, as you know :
When you go into the Details and Advanced tabs to try to alter the framerate and apply the pulldown the pulldown is greyed out and changes made to the framerate are forgotten when you get back to the front page. It was bugging the hell out of me.( , i cant change anything with Mainconcept . Lolz
Yes yes , Jimmy, but i want to do it all in Mainconcept
With Tmpenc , i can encode audio and video separately without sync problem)
Can't encode movie at 720 x 576
By zack28 in forum Newbie / General discussionsReplies: 14Last Post: 5th Jul 2011, 17:25 -
720 x 576 question
By higgins327 in forum Newbie / General discussionsReplies: 24Last Post: 31st Mar 2011, 14:44 -
can't play bd content after authorizing
By volam1 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Oct 2009, 11:38 -
dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
By aljolson in forum Newbie / General discussionsReplies: 12Last Post: 8th Jun 2008, 11:54 -
DVD authorizing
By m baqar in forum Authoring (DVD)Replies: 14Last Post: 28th Mar 2008, 02:51
