Hey,
I tried making a dvd with music vids on it (I didn't need any menus or anything fancy at all, just a ton of music vids on a dvd) so I grabbed Winavi and chose the option of converting any file to dvd and selected the videos (37 in total) and proceeded to convert them. Now the problem I'm having is when I throw this dvd into a player it plays the first 8 with no problems at all, but once the 8th video is done the dvd stops as if it's hit the end of the disc, it still shows there are 37 files and I can skip to any video from 9-37 and play it but once it finishes playing the selected vid (say video 16) it stops after it as if it's the end of the video and wont play straight through 1-37. I'm kinda stumped as to why it does this.
any help would be greatly appreciated.
thanks
B_Drake
Actually I don't have any idea on why it does this.
But you could try another software to create the DVD. Depending on your source material, this should be converted to DVD compliant mpeg2 videos (48kHz!) first. Then you could try to create the DVD with normal authoring software like TDA, dvdlab, GUI for dvdauthor, dvdauthorgui...
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 14:04 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Trouble Creating a on-screen tutorial for PC and Mac
By shmerls in forum Video ConversionReplies: 9Last Post: 26th Dec 2008, 17:33 -
Creating chapters from multiple video files in Sony DVD architect
By MTy in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 12:22
