When I Copies a "Burnt"eg: (Megadeth rude Awaking) TDK disc Using Dvd Decrypter an error comes up 80% threw every single time. so then i tried another TDK disc. (spiderman 2) the same thing Happens.. but when i puts in a Maxell ("The Doors 1968") it copied perfectly.. :S
These TDK Disc are perfect for Burning. and don't Skip in the DVD Player. Just when you tries to copy the burnt copy it don't WORK!... :S.. :@
can sombody explain why this is happening?
Thanks in Advance.
Personally,
I'd stay away from TDK period.
Even back in the days of blank CD's costing $8 a disk, I tried
like 7 different brands and TDK's were the worst ones.
So last year, I said, I'll give their DVD's a try.
The first one was a coaster,
And that will be my last TDK purchase.
i figured out how to do it after. i just when into the disc dir. and copyed the files from there. becuase where its a burnt dvd not copyright protected.
its werid how DVD Decrypter got errors... there must be alot of errors on the dvd..
Can't burn DVD using TDK burner
By tee jay in forum MacReplies: 7Last Post: 16th Sep 2008, 15:01 -
TDK DVD+RW format before use
By nobbydadog in forum MediaReplies: 2Last Post: 30th Apr 2008, 09:55 -
TDK Professional DVD-R media ID?
By lordsmurf in forum MediaReplies: 4Last Post: 15th Dec 2007, 12:08 -
Sony and TDK DVD Discs
By Happs in forum MediaReplies: 14Last Post: 29th Jul 2007, 15:43 -
TDK brand DVD+Rs- These any good?
By Super Warrior in forum MediaReplies: 12Last Post: 28th May 2007, 15:19
