I shot some home DV for my kid and tried to convert them to DVD. However, after I did so, I found there is blur whenever my kid make a quick movement. I wonder whether that is because of the setting from DV to mpeg was not right. I used CCE SP, 3 pass VBR, max 9800, min 0 and ave 6000. Video: DVD compliant. Any suggestions? Thanks!
Make sure you use the correct field order, generally DV is lower field first. There will be a selection for lower field, upperfield or frame based.
if it is dv, it is lower field first ... but buying a $2000 encoder to encode DV was a total waste of money really .. as CCE is not that much (or at all) better for home shot DV ...
your max is really to high also - could have problems on burned media
mpeg conversion using ffmpeg
By rbtechno in forum Video ConversionReplies: 1Last Post: 1st Dec 2007, 03:48 -
Fastest MPEG conversion?
By mingul in forum Video ConversionReplies: 2Last Post: 21st Nov 2007, 16:13 -
there's no sound with my mpeg-1 conversion
By darealest1 in forum MacReplies: 1Last Post: 13th Jul 2007, 08:12 -
mpeg-4 conversion help.
By ruk_design in forum Video ConversionReplies: 2Last Post: 28th May 2007, 03:18
