I am just getting into svcd. Can you help me?
I use premiere to edit my videos. I am to put them onto svcd.
Is it best to capture at 720*540 and then convert it to svcd resolution or is it best
to capture straight to svcd resolution? and then there is no conversion.
Would you get better quality from using the conversion method? Would it take longer?
I use TMPGenc.
Also the latest version has 30 day limit...but you cannot purchase...anyway around this??
Many thanks
Jase
Results 1 to 1 of 1
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
Higher resolution sizes than 720x480 on MeGUI?
By Umandsf in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 08:10 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 14:38 -
How to convert DVD to mkv with 720P or higher resolution
By dharmesh13 in forum DVD RippingReplies: 2Last Post: 21st Apr 2009, 20:47
