Hi,
I have a bunch of rmvb files which I would like to burn onto DVDs for playing in an ordinary DVD player. So I go to the usual route: TMPGEnc + RealAlternative. However some of them refuses to open in TMPGEnc. The error message I got was: "File <filename> can not open, or unsupported". All the files plays fine in Media Player Classic. So I decided to looking into the files a bit using AVIcodec. What I found is the following:
Only files with cook-21 can be accepted by TMPGEnc be converted no problem.Code:Filename V.codec name A.1 codec name 001.rmvb RealVideo 9 RealAudio 8,cook-11 009.rmvb RealVideo 9 RealAudio 8,cook-10 040.rmvb RealVideo 9 RealAudio 8,cook-21
TMPGEnc Version: 2.54.37.135
K-Lite Mega Codec Pack 1.17
Any idea what went wrong? How can I solve this problem? Thank you all very much in advance.
P.S. Also no luck with WinAVI. The error I got was:
"capture file(s)
<filename>
Information failing!
No usable video stream, please make sure that the Media Player can correctly play both the video and audio of the file!"
Have you tried using RealProducer to convert the audio to cook-21?
Google is your Friend
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 10:30 -
so many hours and than it donīt wonīt to work. DVD Slideshow GUI problem
By d.enz in forum Newbie / General discussionsReplies: 10Last Post: 5th Mar 2009, 13:49 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 23:22 -
Film Don't Work On DVD Player...
By Chana1 in forum Newbie / General discussionsReplies: 9Last Post: 23rd Jul 2007, 17:25 -
Dvd's don't work after a while.
By FreeDiver in forum DVD & Blu-ray WritersReplies: 15Last Post: 11th May 2007, 01:46
