Hi,
When I play mpg videos on my computer I have to hike the brightness fader in Windows Media Player right up otherwise the video is too dark. The DVD software I use however doesn't really have a brightness setting, so watching DVDs can be a bit annoying.
There must be some way of permanently adjusting the brightness to solve this. Adjusting the monitor's brightness/contrast just isn't enough, while adjusting my video card has no effect on the DVD or mpg video.
Anyone any ideas what I'm doing wrong?
Alt
Sounds like you have a bad monitor. I just had to replace mine to correct the same problem. My monitor brightness was as high as it would go, and everything was still too dark. You can live with it the way you are already fixing, or replace the monitor which is the real source of the problem.
Google is your Friend -
Try to adjust the overlay settings, find it somewhere under properties for screen - Advanced.
grainy dark video Help
By timbo2288 in forum RestorationReplies: 36Last Post: 17th Apr 2015, 17:48 -
Dark Video
By jan9ella in forum RestorationReplies: 14Last Post: 27th Jun 2008, 14:43 -
Dark video on DVD player
By ckamc in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 12:56 -
How do I brighten dark video (mpg) files before burning to dvd?
By denise4gb in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 22:17 -
captured video is dark, muddy
By arcticranger in forum Newbie / General discussionsReplies: 6Last Post: 11th May 2007, 11:04
