Hi all,
When i shut my PC down it keeps restarting itself. I have re-installed XP etc anyway but also ran ran virus checkers etc to no avail. A friend said it may be to do with wake on lan or soemthing.
I have also found a spyware change in the registry that i cant get rid of. Everytime I 'fix' it using search & destroy it comes back.
DSO Exploit: Data source object exploit (Registry change, nothing done)
HKEY_USERS\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3
HKEY_USERS\S-1-5-21-1801674531-1604221776-839522115-1003\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings\Zones\0\1004!=W=3
HKEY_USERS\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3
HKEY_USERS\S-1-5-19\Software\Microsoft\Windows\CurrentVersion\Inter net Settings\Zones\0\1004!=W=3
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\Cur rentVersion\Internet Settings\Zones\0\1004!=W=3
Im not sure if they are linked but any help would be appreciated as its driving me insane!![]()
Results 1 to 13 of 13
also -- try this:
disable Fast Shut Down"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Try Ad-Aware for your spyware problems. It sometimes asks to restart the machine so it can remove the stubborn stains, leaving Windows whiter than white.
As for the "wake on LAN" issue, look for that option and disable it in BIOS. You normally get to this by holding "DEL" when your machine first starts. It should tell you how to enter "BIOS" or "setup". You'll probably find it under "Power options".
I am not sure what is causing your machine to behave like this. It may be a BIOS option, so take a look.
Good luck,
Cobra
EDIT - ...or listen to BJ_M.
Hi all,
I have tried the sasser worm fix and it says it is not present on my PC. I have also checked out the bios options to no avail as i am not connected to anyother pcs so the 'wake' thing wont matter.
any other ideas? -
bad button ?
unplug the start up button and use windows shut down .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
the actual button turns the pc off. its when i go to start, shutdown it reboots.
what about going to last known good restore point ?
try getting with toghther with shoozleboy "Computer will not boot up"
Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress? -
Have you installed AVG virus scanner and have Roxio installed? If so there's a conflict between the two. There's link on AVG's site to the download on Roxio's site.
If that DSO exploit is showing up in Spybot and you have the latest XP patches ignore it, it's a bug in Spybot. -
If you want to remove the DSO Exploit you saw in SpyBot scan you have to do manually in the registry. Here you can see how to do :
http://www.pchell.com/support/dsoexploit.shtml
I had the same DSO immediately after installed the OS, I don't know if it's a bug or not.Minds are like parachutes. They only function when they are open ! -
Thanks Italic - thats what to do. I had 5 exploits in total - only got 4 now after following that program and after further investigation found it only effects windows explorer and was fixed in service pack 1 - apparently. Im using Mozilla Firefox so i should be OK.
Thanks anyways all! -
http://www.safer-networking.org/en/faq/36.htmlOriginally Posted by Italic
Computer Won't Shut Down
By DarrellS in forum ComputerReplies: 5Last Post: 23rd Jun 2010, 00:51 -
Computer shut down initiated (Log)....... (ConvertXtoDVD4)
By hanse in forum Newbie / General discussionsReplies: 0Last Post: 25th Mar 2010, 15:30 -
Computer shut ByItself, Surge Protector Beeping
By kerrex_2006 in forum ComputerReplies: 3Last Post: 8th Apr 2009, 02:23 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
AVI2DVD causing computer to shut down
By Lynxer in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 09:42
