Hi all. I'm trying to convert a 90 minute program that is roughly 5400MB big at 8000kbps down to about 4300MB at 6400kbps. I use Ulead Video Studio 7 and open the recorded program, do the cut trims to the start and end that I don't want, then re-encode it, but this results in the audio and video being out of sync. Actually it's a bit weird as in the first 10 minutes of the program the sync appears to be good but near the arse end the sync is shithouse. It's like the sync gradually goes out of phase further in the video I think.
Anyways just wondering WHY are these MPEG2 videos so fussy when re-encoding???
The only method I can think of is to separate the audio from the video and re-encode the video and joing the audio up with the re-encoded video.
If anyone can help me find an easy solution to this problem I'd most appreciate it.
Cheers
Troy
AUSSIE!!! AUSSIE!!! AUSSIE!!! OI!!! OI!!! OI!!!
By your description, it appears that you are encoding with the wrong frame rate. If the video is 25fps and you are encoding at 23.976 or the other way round, it will cause a gradual shift in sync. A 40 minute clip will end up with a 1.5 minute shift.
The other thing I've found is that some applications don't like VBR audio for input.
I use VirtualDUB Mod, open the MPEG file, trim it, re-encode it to DivX with a constant quality of 4 and highest performance setting then re-encode it to MPEG-2. Mainconcept, Tmpgenc or CCE Basic are good encoding choices.The more I learn, the more I come to realize how little it is I know. -
Why re-ecnode to divx, then re-encode to mpeg?
Open the file in tmpgenc, re-encode the way you want it. Let tmpgenc do the audio at the same time as video. I've had a lot less headaches this way. If you demux first, and use separate apps to re-encode video/audio, then remux, something is definitely (usually) going to go out of whack). One step, instead of two.Cheers, Jim
My DVDLab Guides
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
How to take 'large' home video mpeg2s and burn to DVD?
By tehfreeman in forum Authoring (DVD)Replies: 7Last Post: 19th Dec 2008, 13:24 -
Encoding has gone bad
By headvi in forum Newbie / General discussionsReplies: 5Last Post: 13th Aug 2008, 20:25 -
I am Legend bad encoding
By stiltman in forum DVD RippingReplies: 9Last Post: 4th Apr 2008, 09:33 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45
