Results 1 to 12 of 12
  1. I did a DVD a while ago in DVDSP2, and I need to edit something. All I need to do it take out 1 track, and possibly edit one menu. All that I have left is the final disc I burnt. Is this possible, or am I pretty well screwed?
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Can it be done? Yes. Will it be a quick fix? No. Still interested?
  3. Rip the DVD. Rip it into the MPEG2 and the AC3 streams (YadeX is pretty easy to use). If you need to edit a menu rip the menu in its own set of streams. The MPEG2 video stream will import into FCP but the AC3 audio will need to be converted to AIFF or another format that FCP will recognize. I have used MPEG2 WORKS for that. Go to the Tools tab, select Audio, select AC3> AIFF.
    Then you can edit away ....
    After that you will have to re-build the DVD
    I think that is about it.
    Have fun !!!
  4. My video and my menus are good. However, I can't quite get the audio. It ripped it in ".pcm" format. I don't believe I encoded this is ac3...but I still can't get anything to play it or convert it. Any suggestions?
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    .PCM is .AC3.
    use MAC3dec to convert to AIFF.
    http://www.versiontracker.com/dyn/moreinfo/macosx/14479
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Oct 2003
    Canada
    Originally Posted by terryj
    .PCM is .AC3.
    PCM is not AC3 - AC3 is compressed while PCM is not (similar to aiff).
  7. Member terryj's Avatar
    I stand corrected.
    http://www.digitalfaq.com/authorburn/authoraudio.htm
    Still, to edit PCM you would need a sound editor able to handle
    the large file. Amadeus II would be able to handle it to edit,
    provided you have ample memory/ disc space for swap.
  8. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Doesn't MPEG2 Works convert PCM audio.
  9. It doesn't have it listed. It doesn't list PCM at all....but I cant do any AC3 stuff in the demo version, so I don't know
    all that ac3dec does is crash....
    You would think A.Pack could convert PCM to AC3...
    Does anyone know if WORKS can convert PCM? If so I may have to spend the 10.
  10. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Try Aiff from PCM
    Perhaps it will help ya'
  11. alright, it worked. Thanks...now for the chapter menu....
