i have been useing dvdshrink, great prog! however, how can i make 2 backups of a dvd? i know i can run the prog twice, but this takes time, having to go through the encoding part twice.
thanks
select "do not burn" .. this will leave the VIDEO_TS folder on your hard drive it (shrink) creates ..
burn the video_ts folder to a dvd disk twice with nero in dvd format"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
or select the burn ISO image with dvddecrypter. After it is done buring the first movie. Pop in a new dvdr and press the burn button on dvddecrypter.
Yep.
You can output to Hard Disk Folders - use your burning software to make 2 copies ...
You can output to ISO Image - use your burning software to make 2 copies ...
You can output to any method you like, with or without auto burning, then do a disc to disc copy of the burnt DVD ...
And there's more ways than that ...If in doubt, Google it. -
whooooo slow down guys,
ill give them points a try, shrink leaves files on HD after burn, so i guess from whats said here i could use nero to dump them onto dvd, just change the volume name to whats on the origional and backup from shrink.
though my next project (a month or 2 away, is backing up vhs, after useing pc to enhance them a little. that nightmare is yet to come)
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
dvdshrink for bluray
By xenotox in forum Blu-ray RippingReplies: 20Last Post: 18th Jul 2009, 09:10 -
Help wanted for DVDShrink 3.2
By _beavis_ in forum Newbie / General discussionsReplies: 13Last Post: 6th Feb 2009, 00:11 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17
