I have a suround reciever that auto detects the sound stream it gets and it tells me that it is PCM 48 and shows me that it is decoding sterio with a Sub woffer channel and I was wondering what PCM 48 is. The source is my satalite reciever also it says that when I watch a show or a DVD in 5.1 it tells me it is decoding dolby digital 3/2.1. Anyway I just thought some of you guys may be able to tell me what these mean.
PCM is uncompressed audio, 48 would be 48khz. PCM 48khz audio is a standard DVD audio format but is not used much because of the space. Most professional discs and consumer software opt for AC3 which is high quality compressed audio.
Look in the glossary for a better definition. -
im guessing the 3/2.1 is 3 speakers in the front, 2 in the back and the sub. although it could be a disc in 3.1 or 2.1. check ur output settings on ur dvd player and sat.
Gillies:
I means a 5.1 soundtrack. The 3/2.1 bit is used by some DVD players to indicate three fronts, two rears, and of course the LFE channel. Why some players use this notation instead of just 5.1, I do not know. Confusing the consumer seems to be a marketing strategy."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Blu Ray LPCM or PCM? That is the question...
By hinsdale1 in forum Authoring (Blu-ray)Replies: 15Last Post: 19th Oct 2013, 18:36 -
AVI container encoded with H.264/AVC video and PCM sound
By LoLaha in forum Video ConversionReplies: 6Last Post: 20th Mar 2012, 23:14 -
Question about sound
By slaughteraus in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2011, 02:51 -
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 05:27 -
no sound after switching from pcm to dolby with power2go..PLEASE HELP
By kingofdabay122 in forum Newbie / General discussionsReplies: 5Last Post: 4th Jul 2009, 10:41
