  1. Hi,
    I need to just take a few clips from a DVD. I have burned and backed up a few in the past without problems, but I have never needed to just take a segment of a chapter till now. I have no idea how to do this. Can someone please help or send me in the right direction? This is for a school project. Thanks!
    Win XP SP1
    AMD Athlon XP 2500
    512 DDR Ram
    Optorite DVD-+RW 4x Drive
    Geforce 4 MX Pro Vid Card
    Twin WD 120 GB Hard Drives
    Albatron KX18D Pro nForce2 Motherboard
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Try DVD Decrypter, you can rip out chapters as mpg, then author as you wish.
  3. Thanks for your help. Just one question. When I have ripped DVD's they are in the VOB file. Where in Decrypt am I able to change file output to MPG etc... I was not able to find it and probably just missed something. Thanks again.
    Win XP SP1
    AMD Athlon XP 2500
    512 DDR Ram
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Look under the "How To" section. Select DVD Decrypter as the tool.
  5. Thanks.
    Win XP SP1
    AMD Athlon XP 2500
    512 DDR Ram
  6. Worked great. Thanks again for your help. Its a lifesaver for this project.
    Win XP SP1
    AMD Athlon XP 2500
    512 DDR Ram
