Hi
I burnt my 1st backup tonight after purchasing my Pio 108. I used DVDShrink & DVDDecrypter following a few guides from this site...
After I burnt in Nero, I tried the disc in my player & every thing was fine apart from the film automatically starting with subtitles. I have to remove them via the remote.
Is there a setting in 'Shrink' or 'Decrypter' that I haven't set right?
Also, my wife has a number of DVD's in Spanish. Is there any way I can back them up with the main language being English & Spanish as the second language?
Many thanks guys for all your help![]()
It's DVD Shrink that causes the problem. I'm guessing you have re-authored and left the main movie only? Right click on the movie file on the left of the re-author window and select Set Default Streams, it's all there
He's a liar and a murderer, and I say that with all due respect. -
Yes, I think I did only save the main movie. I'll try this setting next time & see how we get on...
Thanks a lot -
Originally Posted by Naith
As far as the second channel being Spanish, that will be set there also (unless I'm mistaken) which is entirely possible. Good luck and hope this helps you. -
Thanks for your suggestion
Actually, I'd like to keep the Spanish & English audio PLUS the english subtitles (for my wife's sake).
Is there any way then to change the primary language (which the film starts in) from Spanish to English?
Thanks -
I think so, in the options described above i'm sure you can ask it to display what subtitle you require.
Actually your player has something to do with it too... one of those settings in Shrink "hints" at the subtitle and lets the player decide whether or not to display the subtitles by default. I have three players, two of which will display the subs by default unless I specify otherwise. It's probably good practice to specify the hide sub-picture if in doubt.
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
How do I start?
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Dec 2009, 07:29 -
Backup Blu Ray with partial subtitles
By eon_designs in forum Blu-ray RippingReplies: 4Last Post: 30th Nov 2009, 17:15 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37 -
How to backup and add new subtitles to a DVD
By Paddington in forum User guidesReplies: 73Last Post: 6th Oct 2008, 22:19
