  1. Hi has anybody flashed there drive with a 1.18 firwmare rpc 1
    I found some but can't tell what one i should use
    or if it will work ok.
    http://gradius.rpc1.org/
    any info on this would be great.
    I've heard it lets you rip at x12 instead of the factory set x2
    but dosn't have the x8 x12 and x16 support for media
  2. Member Tidy's Avatar
    Dec 2003
    Texas
    I am using their firmware myself. I have 12x rip speeds and I can choose any recording speed for any media. I have never had any problems with RPC-1 firmware.
    The real answer lies in completely understanding the question!
  3. I did the "For those who wants to convert a DVR-A08/108 drive into a true DVR-A08DX/108DX (aka PIODATA) (support DVD-R @ 16x max and DVD-RW @ 4x max)" from gradius last night, worked like a charm, I now have bitsetting on "+" media by default. I mostly write on "-", but figured I might as well have the best of both worlds.
    Dec 2003
    Houston,Tx
    Me too..... Mines is now a Piodata..
    "What It Do"
    Huh ?????
