  1. I am sorry if I have asked a question that has been answered many times before,, but I have searched this site high and low and can not come up with any thing.
    I need to convert a MPEG file that I created by capturing video with a Dazzle DVC 150 to an AVI. All the programs I have found here (TMPGEncoder) go from AVI to MPEG. Is there anything that will let me go the other way? HAve I missed a setting?
    Thanks for your help!!
    Phil
    Phil
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Virtualdubmod will let you convert mpeg to avi.
    Kevin
  3. Thanks for the fast reply. I am downloading it now!
    Phil
  4. Hi,
    does virtualdubmod support LPCM sound ?
    If not, I could give you some hints.
    greetings
    tom
  5. you can also open the file in tmpeg and select file/output to file/avi file, which also gives you all the benifits of tmpeg like cropping etc and selecting your output resolution or ntsc or pal
    I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
    Rufus T. Firefly (Groucho Marx)
