I have about 10 - 15 VHS tapes I want to turn into DVD's. Here is what i have doen so far. Using the bit rate calc. program, I set my Ulead VS7 paramters to match and capture in MPEG mode first, then I burn the DVD using MF2. So far so good. Since I wasn't editing, I went right to MPEG on the capture. I did this using my ADVC-100 connected via a fire-wire port, no dropped frames. I have been reading on this forum where people recommend hooking the VCR to the camcorder and using the bypass feature, which I just found out I have. Given my current setup , what would be the advantages of using my Digital camera to capture the VCR tapes?
Results 1 to 11 of 11
I use my Sony DV/D8TRV-120 for my VHS transfers.
It works perfectly for me and also stabilizes the VHS video signal. It has some form of a (simple) TBC onboard.
You can always try if it gives you better results ofcourse.
Most DV camera's do a very good job transferring VHS stuff. -
Doman,
I've got the same setup as you (TRV120) and am interesting in converting my VHS collection to DVD. I've been going back and forth between using my TRV120 or buying a Canopus ADVC100. I was wondering if you could let me know the process you are use including software.
Thanks.
MisterBig -
MisterBig,
Go with your current equipments; do not need to spend $200.00+ for the new Canopus ADVC100. It would be no better results as compare one way to another.
BTW, I had the Canopus ADVC100 unit myself. The best and consistent device to capture the analog video. My set-up:
. Capturing with Scenalyzer apps to AVI,
. Edit with Vegas 5,
. Authorize with DVD Architect 2,
. Burn with Nero 6 Ultra. -
In quick steps this is how I transfer my VHS tapes to DVD:Originally Posted by MisterBig
I use a good VCR, (composite will work fine, the quality of the VCR is the most important!) to play the tapes through my TRV120 to my PC. (works great with macrovision too!)
I use the Scenalyzer-Live to capture in segments which I find easier to handle.
Then I edit or cut out the unwanted parts with virtualdub. (or if needed with a real video editor)
After that I use a avisynth script with some simple noise reduction which also puts a black bar over the sides/bottom to cover all the unwanted video noise.
Then I encode it to full PAL DVD (720x576) resolution with Procoder 1.5 (2pass VBR). I never use 352x576, It's just not good enough.
Depending on the source material I put up to about 2 to 3 hours on a DVD.
That TRV120 really does a wonderful job with the VHS transfers!
Really no need for a ADVC100!
I Hope this helps -
use the camcorder, no reason to spend more. the quality will be the same. I use a Canon elura 40, and the quality is the same as the orignal tapes.
Doman,
Thanks for the advice! I will give it a try and get back to you with my comments. Hopefully you just saved me a bunch of $$$.
The initial poster already has the advc-100 and a digital camcorder with a passthrough feature. So either one should give him similar results. The best way of knowing for sure is by trying both options.
Where is Vhelp when you need him. He captures both with a digital camcorder and the ADVC-100. He's also done numerous test between the 2.
First I saw he liked the camcorder better, then I saw he liked the Canapus better. Not sure what he settled on. Unless your zooming in and very picky you probably won't see any difference.
I use my passthrough on my DV cam and am very pleased with the results.
Nice thing about ADVC-100 is that you do not tie up your camcorder, and I think I saw somewhere it has some very slight filtering built in to help the quality of the video. Not sure if true though. -
swroberts,Originally Posted by swroberts
I am assuming you have a digital cam. If so, I say find a challenging scene or small challenging segments on one or more of your VHS tapes. Try each device to see which gives the best results. Challenging scene = lots of movement/action and/or camera shake or pans and/or crazy zoom in and out, etc.
In my experience, the ADVC-100 is a great little device, but I found that it needed some help with old VHS tapes (like Time Based Correction and Video Stabilzer). A digicam may come in handy here, moreso than the ADVC-100 by itself. Do some small test clips. -
Using the passthrough feature will also sometimes help on old tapes. At least, it's been my experience with one of my tapes. I wouldn't be surprised that the DVC-100 does the same thing. It's not a built-in TBC but it has similar results to one. For example, the passthrough feature of my Sony camcorder corrects for any macrovision effects. I believe that the ADVC-100 does the same thing.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:26 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
