error
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 9:20:56 AM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero API version: 6.6.0.3
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <ATAPI DVD DD 2X16X4X16> Version: G7H9 - HA 0 TA 0 - 6.6.0.3
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
CdRomPeripheral : ATAPI DVD DD 2X16X4X16 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : BENQ DVD-ROM 16X atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3160827AS 3.42 viamraid Port 2 ID 2 DMA: Off
=== CDRom-Device-Map ===
ATAPI DVD DD 2X16X4X16 D: CDRom0
BENQ DVD-ROM 16X E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 278MB (284992kB)
Memory in use : 45 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.1.2005
NeroAPI
8:47:28 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
8:47:28 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
8:47:28 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
8:47:28 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
8:47:28 PM #5 Text 0 File Writer.cpp, Line 122
Writer ATAPI DVD DD 2X16X4X16 running
8:47:28 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
8:47:28 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3286
First writeable address = 0 (0x00000000)
8:47:28 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3286
8:47:28 PM #9 Text 0 File Burncd.cpp, Line 3151
Turn on Disc-At-Once, using DVD media
8:47:28 PM #10 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 1656873 (368:11.48, 3236MB)
8:47:28 PM #11 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO
8:47:28 PM #12 Text 0 File DlgWaitCD.cpp, Line 2309
Recorder: ATAPI DVD DD 2X16X4X16, Media type: DVD-R
Disc Manufacturer: TYG02 -
Disc Application Code: 64, Disc Physical Code: 193
8:47:28 PM #13 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
8:47:28 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1657024 (1657024) = #1657024/368:13.49
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1657024 blocks [ATAPI DVD DD 2X16X4X16]
8:47:28 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1040
Prepare recorder [ATAPI DVD DD 2X16X4X16] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3393585152, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1657024 | lead-out | 1 | 0x41 | 0x00
8:47:28 PM #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
8:47:28 PM #17 Text 0 File Burncd.cpp, Line 4038
Cache writing successful.
8:47:28 PM #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
8:47:28 PM #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 16x (22,160 KB/s)
8:47:28 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2596
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
8:47:28 PM #21 Text 0 File DVDR.cpp, Line 2248
Recording mode: Sequential Recording Mode
8:47:28 PM #22 Text 0 File Mmc.cpp, Line 21025
Set BUFE: Seamless Link -> ON
8:47:28 PM #23 Text 0 File DVDR.cpp, Line 2389
Start write address at LBA 0
DVD high compatibility mode: Yes
8:47:28 PM #24 Text 0 File Cdrdrv.cpp, Line 8315
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:47:28 PM #25 Text 0 File DVDR.cpp, Line 5611
Drive: ATAPI DVD DD 2X16X4X16
Book Type request: DVD-ROM
Drive doesn't support changing Book Type for DVD-R
8:53:29 PM #26 SCSI -1135 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x00DD0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0xAD 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x00
8:53:29 PM #27 CDR -1135 File Writer.cpp, Line 311
Write error
8:53:29 PM #28 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
8:53:29 PM #29 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
8:53:29 PM #30 Text 0 File DVDR.cpp, Line 2632
EndDAO: Last written address was 44319
8:53:29 PM #31 Text 0 File DVDR.cpp, Line 5611
8:53:29 PM #32 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 16x (22,160 KB/s)
8:53:29 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
8:53:29 PM #34 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
one topic is enough, https://www.videohelp.com/forum/viewtopic.php?t=250800&highlight=
please don't use subjects like please help me
AVStoDVD help pls!
By merovingio in forum Video ConversionReplies: 1Last Post: 15th Oct 2011, 18:25 -
Avisynth Filters (help pls)
By Enkidu in forum EditingReplies: 14Last Post: 30th Jul 2010, 22:41 -
Hello pls l need help on mhc-gvn111d
By kunxx in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2010, 09:55 -
pls or m3u to avi
By py52126 in forum Video ConversionReplies: 1Last Post: 20th Jan 2009, 15:35 -
mkv to avi , help pls
By a_n00b in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 05:17
