I found this but didn't want to threadjack.
https://www.videohelp.com/forum/viewtopic.php?t=250936&highlight=tbc+pci
so...
I was very interested in the TBC-100 until I saw "NO AUDIO INPUT - NO AUDIO DELAY PLEASE SEE TBC-1000" on the Datavideo site. Are there ANY TBC's out there that are a PCI card and have BOTH the audio AND video inputs??? I already have a pci capture card with both audio & video inputs. I want to a) be able to back up commercial ntsc vhs tapes (by removing mv) that I own and b) stabilize the signal that tbc's are known to do. I think the out-of-sync audio is one of the most common problems found when capturing, along with frame dropping of course. I'll get a standalone unit if I have to. Would have been nice to save some cash while I was at it though, $300 is kinda high for the volume I'd be doing. thx
Why does it matter?
The audio is merely passthrough.
The TBC does absolutely nothing to it.
The only reason the TBC-1000 has audio is because the unit acts as a high quality split with 4 outputs. Otherwise, no reason for audio inputs.Want my help? Ask here! (not via PM!)
I believe it says "no audio input - no audio delay"
Then the next line says "see TBC-1000" which would indicate that the PCI card has no audio pass thru and there's no audio delay. But for audio pass thru see the TBC-1000. Got it?
Steve
Datavideo TBC-1000 audio inputs question
By gymnastgirl in forum Capturing and VCRReplies: 5Last Post: 20th May 2010, 07:17 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
How to add a VCR when I don't have any more inputs except Serial & 15P
By Alucard41 in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2008, 15:40 -
HP m7760n video inputs ~ how do I get these inputs to work?
By FTLOSM in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2007, 20:19 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58
