Hi,
I'm looking for good software that can disable the copyright protection on a DVD upon inserting the disc. I was using "AnyDVD" for this, but I discovered this program was causing my DVDROMs to freeze randomly. Does anyone know any programs similar to AnyDVD or any that can rip individual scenes rather than long chapters?
Thanks,
Kristin
Hello,
Dvdshrink can.
Go into reauthor mode. Select just the main movie. Then go into the Start/end button and you can select just the amount you want - not just the chapter.
Rip using DVDDecrypter or Smart Ripper, or DVDShrink (I find this one less reliable - personal experience maybe?).
Find the VOB(s) with the scene(s) in you want. If you want the whole movie, rip to one big VOB file.
Load the relevant VOB(s) into VirtualDubMod (not to be confused with other flavours of VirtualDub).
Set the start and end frames to the specific section of film you want and save to AVI. Make sure that a DV codec is set to be used in the "Video" -> "Compression" settings.
If you don't have one, or the existing one doesn't work - try the Panasonic DV Codec.
I've recently done exactly what you want to do (also with Premiere) and it works beautifully.
If you're not sure on how to do the various bits with the tools mentioned, read up in the guides or look in the forums. Only when you get stuck, post back and we'll try to help.
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Help! I can't "Rip Video DVD to hard disk" (AnyDVD HD 6.7)
By jin37uk in forum Blu-ray RippingReplies: 3Last Post: 23rd Oct 2010, 23:32 -
VHS-->DVD, "action scenes" and bad sources
By Jdrive in forum Capturing and VCRReplies: 7Last Post: 13th Oct 2010, 00:09 -
Post examples of scenes with "fade" in them for encoding w/ x264
By vhelp in forum Video ConversionReplies: 1Last Post: 8th Sep 2009, 02:27 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
"Sliced" playback during pans and action scenes.
By GMaq in forum Software PlayingReplies: 9Last Post: 1st Nov 2007, 09:07
