Results 1 to 10 of 10
  1. Hi all,
    I have a problem with DVD-LAB Pro.
    When I import a MPG media I get the following error
    Any Help
    Some Day I will…..
  2. Please
    Some Day I will…..
  3. Corrupt mpeg?
    Hacked warez version of dvdlab?
    Cheers, Jim
    My DVDLab Guides
  4. Appreciate you coment bot, No Hacked warez version, I download the trail for 30 days.
    MPG can be read by other applications.....
    Any
    Some Day I will…..
  5. I would think it's got to do with dvdlab's demuxing process.
    Demux the mpeg in tmpgenc first, then import the separate audio and video into dvdlab.
    Should work, providing the mpeg video stream is mpeg2 compliant, and the audio is either pcm, mp2, or ac3.
    The two situations I mention above, are the only two I've come across that generate that error.
    Cheers, Jim
    My DVDLab Guides
  6. I know that with the hacked version you can have any thing.....
    I also try demuxing before and it will take it but when it come to compile fail, it just present the DVD-LAB Logo in the pre-vew and thats it.
    Don't know any more..........where am I.
    Some Day I will…..
  7. You have an mpeg with a problem.
    Something about it is not compliant with dvdlab's specs. It could even be a renamed wmv.
    Try re-encoding the mpeg in tmpgenc (demux, then remux using mpeg2 (SVCD) in tmpgenc's mpeg tools).
    If that fails, totally re-encode the whole mpeg to spec.
    You could try posting on the help forum at www.mediachance.com or re-downloading the trial...
    Cheers, Jim
    My DVDLab Guides
  8. Thanks for your help, one of the thing that I try, it was to copy the application (the download one) from my laptop to my home PC, and in my home PC works fine, but I need that application to work in my laptop, because most of the time I am in the road working with my laptop.
    Thanks again for you help. I will try the help forun
    Some Day I will…..
  9. It was a problem with the version. 041025, I went back to 041014 and it work fine.
    Thanks again
    Some Day I will…..
  10. Glad to see you got it sorted Thanks for replying.
    Cheers, Jim
    My DVDLab Guides
