I have a disc, which I believe is a VCD. I'm trying to convert it to a DVD. After searching the forum and reading the only thread that seems relevant, I made a .bin image of the disc. Using the conversion tool in ffmpegX yields this:
++ WARN: detected wrong size calculation for form2 file `CDI/CDI_IMAG.RTF'; fixing up
INFO: detected extended VCD2.0 PBC files
INFO: extracting CDI/CDI_IMAG.RTF to _cdi_cdi_imag.rtf (lsn 220, size 1315168, raw 1)
INFO: extracting CDI/CDI_TEXT.FNT to _cdi_cdi_text.fnt (lsn 863, size 13616, raw 0)
INFO: extracting CDI/CDI_VCD.APP to _cdi_cdi_vcd.app (lsn 870, size 102400, raw 0)
INFO: extracting CDI/CDI_VCD.CFG to _cdi_cdi_vcd.cfg (lsn 920, size 193, raw 0)
INFO: extracting avseq01.mpg... (start lsn 1264 (+45846))
INFO: extracting avseq02.mpg... (start lsn 47110 (+44894))
INFO: extracting avseq03.mpg... (start lsn 92004 (+87393))
INFO: done
Input #0, mp3, from '/Users/peterl/Movies/Disc1.bin.contents/avseq01.mpg-0.mp2':
Duration: 00:10:07.7, start: 0.000000, bitrate: 224 kb/s
Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
Output #0, mp2, to '/Users/peterl/Movies/Disc1.bin.contents/avseq01.mpg-0.s.mp2':
Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
ffmpeg version 0.4.9-pre1, build 4736, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads
built on Dec 18 2004 04:39:28, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
video:0kB audio:16617kB global headers:0kB muxing overhead 0.000000%
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] File /Users/peterl/Movies/Disc1.bin.contents/avseq01.mpg-0.m1v unrecogniseable!
INFO: [mplex] File /Users/peterl/Movies/Disc1.bin.contents/avseq01.mpg-0.s.mp2 looks like an MPEG Audio stream.
**ERROR: [mplex] Unrecogniseable file(s)... exiting.
Any ideas? Thanks.
I processed the .DAT files to get .mpg files with Gumby. Those resulting .mpg files play fine in Quicktime Player, VLC, mplayer, etc.
The reason for the conversion is that I need to get these playing on a portable DVD machine for a trip. It does support playing MPEGs from a data CD/DVD, but it does not support S/VCD nor does it support MP4.
I put the .mpg files I got from Gumby onto a UDF formatted CD-RW, and they worked fine in the player. Emergency over.
I'm still curious to see why the conversion didn't work in ffmpegX...
Problem with mkv to DVD conversion
By LoafingOaf in forum ffmpegX general discussionReplies: 0Last Post: 27th Oct 2009, 07:46 -
problem with conversion from DV-AVI to DVD
By obadvw in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 18:08 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
DVD to ipod Conversion Problem
By Cirone328 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2008, 12:29 -
WMV to DVD or VCD Conversion
By MannyNoela in forum Video ConversionReplies: 9Last Post: 6th Feb 2008, 11:22
