  1. Which is the best...I now have installed the kristal studio codec, but I cannot play with windows media player...
    Do I have to deinstall the kristal studio first..???
  2. if you click that link to the left that says tools and scroll down the list to codecs you will find an mpeg2 codec that allows you to play them in WMP
    should you uninstall kristal?
    well you dont have to but you probably should since every codec package i have ever seen sucks. install the mpeg 2 codec and then get DivX 3.11 alpha as well as DIVX 4.11 (but dont allow DIVX 4 to decode DivX 3.11 content, it doesnt understand DivX audio and can cause a problem with some files)
