i made a anime dvd, seem everyting was okay,
6 episodes videos *.m2v (AVG 3300kbps)
12 Audio, AC3 224Kbps
6 subs picture files
+simple menu
all compiled wit no problem and checked with ifoedit dvd play, perfect
but when playing with my toshiba SD-2950 standalone dvd player some part with JAP audio freezes (added later:actually it seem it freezes for different stream @ diff. time/frame)
*burnt with nero 6
is anithing wrong i did? =.= the dvd i burnt i play back on PC is okay, ut i oni got 1 standalone dvd to check
the *.avi (from OGM) AVG bitrate never went >2500K @ all so i juz used 3300K, wonder if its insuffient or sort
anione explain pls?
I have the same problem as you. I convert my ogm/mkv to mpeg2 using tmpgenc and author them using dvd-lab pro and my dvds also freeze during playback on one of my dvd players. I have a feeling the problem is dvd-lab pro because when I used dvd architect 2 the dvd played just fine. I reported this problem but they haven't came out with a fix.
I also have the same problem with dvd-lab pro so I use dvdComposer
and the dvd played perfecly on the dvd playerjma -
Not related to your problem, but what bitrate used for video in the AVI is completely irrelevant when choosing mpeg2/DVD bitrate. What matters is what quality you want, and how much space (the DVD) you've got.Originally Posted by animaxx
The DVD specs doesn't define any lower bitrate limit, and 3300 kbps is fine, at least for 1/2 D1 resolution.
I would bet on media compatibility issue here. Try other manufacture of DVD, try +r instead of -r (or vice versa).
/Mats -
I also think something like that so I made a test.
What I did was that I autored a DVD using DVD-LAB PRO and burned and it freezes but then I autored the same dvd files with dvdcomposer and
then burned but this one dosen't freeze.So I dont know if is the bitrate.But I dont really know if is only
with anime episodes that have multiple audio streams because when I author with dvd-lab pro other movies thet aren't japanese anime they work just fine so don't really know the problemjma
dvd lab pro movie numbers regularise
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 02:28 -
How do I retain Chapter Points from Movie? [DVD Lab Pro 2]
By SupaDupaMonkey in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2009, 19:56 -
DVD Lab Pro - Question about movie merge
By shashidar in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 16:41 -
DVD Lab Pro - Movie clips in menu
By flipzoso in forum Authoring (DVD)Replies: 1Last Post: 26th Oct 2007, 03:38 -
End Movie Scrooling Titles in DVD-lab PRO
By fwerneck in forum Authoring (DVD)Replies: 2Last Post: 14th May 2007, 05:16
