  1. Hi All
    I use the TMPGEnc 3.0 XPress for converting avi file.
    Which parameters for video should I choose, in order that scenarist will
    accept and register it?
    Shaul
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    that is covered in great detail in Scenarist manual - plus in the training your dealer gave you when you purchased it ..
    It must be 100% DVD compliant though ..
  3. Thanks,
    But it does not help. I tried in TMPGEnc 3.0 XPress to find the right
    parameters but I have still a mistake as Scenarist does not register
    the video file only the audio file. Any help will be much appreciated.
    Shaul
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    are you creating elementary streams ?
    have you read the manual ?
    If you can afford to use Scenarist (17-25,000$) , you SHOULD be using the sonic hardware encoder anyway - whuch is much better quality .. in fact 90% of all Scenarist systems come with the encoder as this system is sold almost always as a package -- since there not many Scenarist systems sold, but does nclude good support .. i will forward your contact info to Sonic Scenarist staff (whom i know fairly well) and they will contact you about why you are not using the Sonic Encoder in your system .. They will want to know your dealer also (there are only a few dealers) ..
