this is right now but in a couple days i should be gettting my new one then ill repost
Results 31 to 48 of 48
My Computer:
AMD XP3200+ Barton 2.2 Ghz 400 MHz FSB
2x 256 PC 3200 in Daul Channel
Sapphire Radeon 9600 Pro Alantis Advantage Edition 256 MB Video Card
Daughters Computer:
AMD Sepron 2800+ 2 Ghz 333 Mhz FSB
256 MB PC3200
ATI Radeon 9200 128 MB Video Card -
Well, I do have another Corsair 1GB dual-channel RAM kit (making 2GB in total), but I can't get my motherboard to run four sticks of RAM reliably even at 200MHz (DDR400) with 2T command rate. Never mind - this RAM really screams along. As for the CPU - it is equivelant to an XP3800 now, just with a much higher FSB.
I am disappointed with not being able to have 2GB of RAM, but there you go. It's a very fast system anyway.
That's what's under my bonnet (or hood for Cap).
Cobra -
COme on. I want to see someone elses overclocked machine. Cobra you dissappointed me. I thought you'd be smooth at 8G with your machine in the home Freezer. :/
My machine is completely stable, and runs on quiet air cooling. All I have done is taken the components to their practical limit, instead of going to extremes and achieving the actual limit.
Have you thought of liquid cooling? I have a couple machines with it and it's virtually silent. Just 2 silent running fans by the radiator. You wouldn't even know they were on unless you put your hand by them or put you ear right up to the box.
I have a few problems with liquid cooling:
- Can't afford it
- Makes moving the PC hard
- Needs maintenance (topping up etc.) - can't leave my PC running for a week at a time unattended
...although I see the huge benefits of near-silent operation, powerful cooling ability and looking just so cool!
Cobra -
I have a float in mine. I have a small pipe going from the bathroom nearby into the room with the computers. It's in the wall. The pipe is the kind used in refridgerators for the water & ice dispenser. It's copper pipe, not hose. I have a float assembly that turns the water on if the level gets too low. If I didn't have it, I'd need to fill the thing every day being out here in the desert. It's completely contained so it won't break or leak. I am thinking of adding a small wash station in the room too. Place a small fridge and microwave in there too. Honestly, I need to buy a new house, but costs are so high I couldn't afford the value of my current home. Appreciation shot through the sky here. I didn't do the 4G CPU system myself though. Don't know squat about overclocking.
Originally Posted by Doramius
Look at my signature. Give it ten minutes, and you'll understand a little more (I hope).
Anyway, back to the thread! Who's next? -
Yeah right. If I use your method, I'll fry my computer. I might have enough time to get a screen grab of a 6G speed and then smell burning plastic. I'd mess it up so bad. I'm not the best at that delicate work.
What's wrong with my method?
Doramius,
could you post some pics if possible?
I'm always o/c'ing but have never had the
guts to use even a stock off the shelf water cooled
system. -
Well, it is "under the bonnet" in the most direct sense! Let's see it!
Originally Posted by offline
Whoops. I think I reversed the bottom pic.You can see it though.
I was afriad at first to do water myself, because I put a lot of money into it. I didn't even try to do overclocking myself. First because I suck at it, and 2, I suck at it. However, I found the water cooled systems run nice. My Lian-Li tower has a water cooled system in it now, but it and this are the only 2 out of 5 systems now. All intel. These are just pics I have. I'll see if I can get more over the weekend and post.
Nice.. some white light pics with the fluro's off would
be nice. What brand water rig is that? -
It's a combo of different blocks and the hose and fittings I got from Fry's (aka Outpost.com, but there's an actual store here). Thermaltake is the main water unit. I'll have to take some more pics, but those are the one's I have on my work laptop.
I also think it looks more impressive with the neon colors.
