i came across this and it claims to speed up page loading. won't work for me but it may work for someone else....
http://forevergeek.com/Here's something for broadband people that will really speed Firefox up:
1.Type "about:config" into the address bar and hit return. Scroll down and look for the following entries:
network.http.pipelining network.http.proxy.pipelining network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it receives.
If you're using a broadband connection you'll load pages MUCH faster now!
good luck.
Results 1 to 13 of 13
about:config is interisting -- thanks (note: can really screw up browser)
i meant changing other settings there
Try "Tweak Network Settings" at http://www.bitstorm.org/extensions/ and check out these 2 links.
1 http://forum.osnn.net/showthread.php?t=44788
2 http://www.neowin.net/forum/index.php?showtopic=243907 -
Remember if you make a ton of request at a time the server may ignore you and admins will hate you.
what does this mean. i don't really know what my first post meant, it just came recommended from a trusted source and i passed it along. i don't have broadband so i can't even try itOriginally Posted by flaystus
What I mean is one of those settings basicly makes your browser bombard the server with connection request if I'm reading right.Originally Posted by Dr. DOS
you're probably right. you know a hell of a lot more about this stuff than me. here is the mozilla explaination......Originally Posted by flaystus
http://www.mozilla.org/projects/netlib/http/pipelining-faq.html
Security risks for wireless broadband?
By yogart in forum ComputerReplies: 10Last Post: 16th Feb 2010, 13:49 -
IPS Wireless Broadband security
By yogart in forum ComputerReplies: 0Last Post: 8th Feb 2010, 12:45 -
Changing Broadband From AOL To Sky Help
By Nitro89 in forum Off topicReplies: 0Last Post: 12th Dec 2008, 15:36 -
Mobile broadband USA
By rhegedus in forum ComputerReplies: 14Last Post: 1st Nov 2008, 12:26 -
Comcast to cap monthly consumer broadband starting Oct. 1
By stiltman in forum ComputerReplies: 38Last Post: 31st Aug 2008, 11:07
