I recently converted a DV avi to mpeg2 with QuEnc 0.57. I have 1 problem and 1 question. The resultant mpeg had no audio. I'm wondering if since I used a Type 1 DV avi this was the problem. Should I use Type 2 avi with QuEnc to take advantage of the internal ac3 audio?
Also, when I encoded, the GOP was set to 18. I'm not sure why it was set to that, but I just read in one of the user guides, a GOP of 12 should be used when the destination will be dvd. Do I need to reencode (another 20 hours on my slow machine) with a GOP of 12?
Thanks,
Andy
okey...the latest versions supports audio...
...but you can still try use a separate audio encoder.
The gop should be 18 for NTSC. Read http://dvd-hq.info/Compression.html
Thanks Baldrick. I think I'll try one of the dv type converters o change my avi to type 2. Virtualdub does not like type one. Then I'll strip out the audio and mux with my m2v that I got from QuEnc.
quenc 0.72 catching with movies (xvid 1.3.0)
By sgbd in forum Video ConversionReplies: 1Last Post: 13th Nov 2010, 19:41 -
Quenc Settings
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 14th Jun 2008, 19:57 -
Quenc Frontend
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 10th Jun 2008, 22:01 -
Quenc Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 16Last Post: 3rd Jun 2008, 10:36 -
CCE, Procoder, Quenc or HCEnc: which one do you get better results?
By devilcoelhodog in forum Video ConversionReplies: 28Last Post: 31st Jan 2008, 21:41
