Hi!
I got the following problem:
I have 2 DVDs and each dvd is 2gb big!
so i wanted to make one dvd out of it!
now i put the ifo/vob files of each dvd in a seperate folder, so i got one folder for each dvd!
Then i tried to make a dvd out of these 2 folders with DVD LAB pro!
I added each dvd by using the "Attach external VTS" function(File-> Attach external VTS)!
Then i made an VMG Menu for it!
When I want to compile the DVD it always tells me that I have to have at least one movie in each vts("There is no movie in VTS1")!
So I tried to delete VTS1 but it just doesnt delete it!
As I just use VTS Import1(DVD1) and VTS Import2(DVD2), how can i get rid of VTS1??
Thanks for helping!
"now i put the ifo/vob files of each dvd in a seperate folder, so i got one folder for each dvd"
What do you mean by that? Folders have nothing to do with DVDLab.
You want to make one dvd from two, why are you trying to delete VTS1?
Can you not just import the two, and join on the connections tab? Then add chapters, menus, whatever, and it will play as one movie, or try reading this thread: https://www.videohelp.com/forum/viewtopic.php?t=251207Cheers, Jim
My DVDLab Guides -
i have made a 2 movie dvd lab but i used WinAVI to convert to dvd, it works well for me u could always try that instead, and as for the 2 folders thing u can do that just make 2 movies so with the list of all the menus and movies to be burned it should say movie 1 and movie 2 and just put 1 movie on each for as many as you want. hopefully that helps...
-shaun
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53 -
Home video too big for DVD. How do I put it on 2 DVDs?
By Saaski in forum Newbie / General discussionsReplies: 12Last Post: 14th Jan 2008, 16:00 -
Help with DVD-lab pro
By Jack the Ripper in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 07:21 -
Editing Nero made DVDs: DVDauthorgui? dvd lab pro? Gui4dvdauthor?
By KneeRow in forum Authoring (DVD)Replies: 31Last Post: 22nd Aug 2007, 01:41 -
how do i put srt file in dvd lab pro?
By oilpourer in forum Authoring (DVD)Replies: 6Last Post: 1st Jul 2007, 18:20
