Hi,
A while ago i needed to convert AVI to DVD.
With the help of this forum i managed to devise a procedure that worked for me with the programs i had and enabled me to tweak the bits i need to tweak.
The problem i now have is that i havent done one for ages and I am having difficulty follwoing my own instructions! and i am afraid my memory is really poor (and LOTS of other stuff job and family going on)
Can anyone help? Please...
My instructions are as follows
AVI ---> TMPGEnc ----> MPG
MPG ---> TMPGenc (File -> MPEG Tools -> De-Multiplex) ----> MPEG
MPEG + Audio ---> IFOEdit (DVD Author -> Author New DVD -> Add Files) ---->DVD Files
then thru DVD Shrink, Nero and DVD Decrypter onto DVD
The second half DVD Shrink onwards I can remember and have detailed instructions for.
Its the first half i am having difficulty with... i ahve done the first bit and got two files M2V and MP2....and dont now know what i need to do.
Thanks in advance
Hello,
Here's a guide that might refresh your steps:
https://www.videohelp.com/guides.php?link=697
Also m2v is the video and mp2 is the audio for a reminder
There are more avi to dvd guides in the "HOW TO" section on the left for a refresher course
Kevin
By the way - why are you using dvd shrink??? Once you get a dvd compatible mpeg2 file all you need to do is author it with a dvd authoring program like tmpgenc dvd author
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thank youOriginally Posted by yoda313
thanksOriginally Posted by yoda313
yup, and i looked, but couldnt marry any of them up to the instructions i already have! 8)Originally Posted by yoda313
I am very much of the school of thought of One Tool - One Job so i only use DVDDecryptor to burn DVD's and as such need DVD Shrink and Nero to produce the ISO.Originally Posted by yoda313
Thanks v much....helpful reminders.... -
Originally Posted by zworg2Basically you've done the first two steps in oneOriginally Posted by zworg2
According to your notes, you would have outputted an MPEG file using the System (video and audio) setting. Instead, you have outputted an M2V and a MP2 file using the ES (video and audio) setting.
That's fine - all it means is that you have already done the MPG ---> TMPGenc (File -> MPEG Tools -> De-Multiplex) ----> MPEG step in combination with the AVI ---> TMPGEnc ----> MPG step (there is nothing wrong with doing it either way, I might add). Go straight to the IFOEdit step and you should be good to go
If in doubt, Google it. -
Originally Posted by jimmalenko
Aaarrr!! - Suddenly it all becomes clear.....
Thankyou....
Zworg2
Installation/Uninstallation instructions
By Jirka Cech in forum ffmpegX general discussionReplies: 57Last Post: 24th Apr 2012, 17:45 -
Instructions for DVDShrink with ImgBurn?
By JohnnyBob in forum DVD RippingReplies: 29Last Post: 9th Sep 2010, 16:00 -
Need instructions on how to use avi.net
By snafubaby in forum DVD RippingReplies: 1Last Post: 21st Dec 2008, 19:05 -
encoders supporintg SSE4 instructions
By tommcd64 in forum Video ConversionReplies: 4Last Post: 17th Sep 2008, 16:41 -
Camera Mount Instructions for a Bicycle
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jun 2007, 16:42
