Good tip. Maybe I'll finally update to v. 0.69. Been using v. 0.52 for quite a while, no problems, but remember the difficulty finding an MPEG2DEC version that worked properly.Originally Posted by Heff![]()
Results 31 to 39 of 39
Pull! Bang! Darn!
There is a new version of the installer with the latest versions of RB and quenc.
http://forum.doom9.org/showthread.php?s=&threadid=84487&perpage=20&pagenumber=1 -
Originally Posted by budz
I use Shrink / Decrypter combo.
Never had a problem, only have 21/23" (i not sure and cant be arsed to check).
I have never been toooooo worried ablut the quality tho.....as long as it isnt grainy... -
I sometimes use DVDAuthor first, then Shrink. I am very picky about quality. I generally work hard to get movies to at least 95%, like cutting out long openings and credits (unless the opening is integral to the movie). I cut out all languages but English. I then decide whether to use a menu or just a movie only. After I work down through these decisions, if I'm not in the mid-90's, I may decide not to copy at all and go with the original. On rare occasions I have gone to about 85%.
Another topic: I have used Intervideo DVDcopy and it looks good, but can't see any improvement over Shrink, but it got excellent reviews at http://dvd.box.sk/articles8.php, in fact, picked as the best, while Shrink was picked as the worst. Although it is an old test, with an older version of Shrink. What bothers me is that Intervideo leaves about 100,000 bytes not used on a dvd5. It seems like it would be more efficient if it used the extra headroom. Is there a setting that I'm missing?
I tested the link after posting and it didn't work because it is putting the comma at the end into the address box. Try this:
http://dvd.box.sk/articles8.php -
Hi all, and happy new year.
For those who do not have the time to do the work, but are on a fast connection...
http://www.dvdshrink.info/temp/beta/comparative_tests.html -
I'll release a new Installer with the new Public Release of DVD Rebuilder... today.
Check it on www.dvdrebuilder.com
keep it UPMy oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
I've had to use DVD-RB on some discs Shrink REFUSED to see. I used REJIG with DVD-RB, worked great.
Decrypter is a ripper, but can read/write ISO. Not the same as the others.Want my help? Ask here! (not via PM!)
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 26th Sep 2010, 23:52 -
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 14:54 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 15:55 -
RipIt4Me, DVD Shrink, and DVD Decrypter on Vista?
By RowMan in forum DVD RippingReplies: 1Last Post: 24th Oct 2007, 22:45
