Results 1 to 9 of 9
    Apr 2002
    New Jersey
    Is there any way to minimize the splash screen when converting to DVD with dvd Santa? The proccess takes HOURS and I would like to be able to view/do other things, but that particular screen will not minimize. Any suggestion?
    TIA
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    does purchasing it help (remove the splash)? (i dont know as i never used it) ..
    Apr 2002
    New Jersey
    BUMP!
  4. If you are talking about the logo on a burned dvd, then you have to purchase it. It says it right on the screen when you try to create a dvd using Santa. If you buy it, the splash logo will no longer be there.
    Sorry man. Good program otherwise though
    LG
    Apr 2002
    New Jersey
    Nope..NO logo on burned DVD. It's the splash screen when doing it's conversion thing.
  6. Oh, my bad. Erm .. then Im not sure. I havent really noticed it but only because when I start converting something, I just leave it and come back in a few hours.
    I'll give it a try tonight and let you know.
    LG
  7. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Try Alt-Tab ... this won't minimize the splash screen but this will allow you to move between different applications that you have open. For example, if you have Windows Explorer, Internet Browser, Mail Application and then open and run DVD Santa, you should be able to use Alt-Tab to go between those four applications. I know it's a workaround but at least you should be able to do something else when DVD Santa is going.
  8. no you cant get rid of the converting screens or the one behind it,just move them to the corner and just live with it.
    LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
    Apr 2002
    New Jersey
    Actually I found you CAN be rid of the other screens and move the conversion screen where you want. PITA....but at least workable.
