I have the tv wonder ve with a soundlaster sound card, win xp pro
any ideas why i can capture once perfectly and then bam no sound on the next ( once I close the capture program), Ive tried about everything I think if any body had had to deal with this please let me know
Ive tried v -dub anfd I get unsupported format 9it works the first try after boot), iu vcr works great once, and avi_io works great once.
It happens for VFW applications under win2000/xp (having WDM drivers).
Once wxiting such application it mutes the sound. So, before you run it again start original app (MMC I mean), then exit from it and then run VDub, .. whatever.
Yeah Ive kinda read about some of the stuff,
but once i use another program and close it I cant open mmc because it says the device is in use.
any ideas?
Wouldnt you think I could into the audo setup and unmute it, or is it some kind of internal mute or something
so, it doesn't release device properly - you have to restart your computer. Sometimes I have this but not quite often.
I suspect it won't help - it mutes sound in the tv card itself.
Actually Ive worked this out.
Ivan from iuvcr walked me through it at 2 am last night, talk about support, it does mute the line in but iuvcr lets you unmute it.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I am also having this problem. How did you work it out? Thanks
Does this sound like a MOBO issue?
By beavereater in forum ComputerReplies: 9Last Post: 7th Feb 2012, 07:59 -
DVP5992 Philips sound issue
By udidwht in forum DVD & Blu-ray PlayersReplies: 11Last Post: 21st Nov 2010, 22:58 -
Help on sound issue - possible DX plugin - thingy
By squadjot in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2009, 11:05 -
vob2mpg sound issue with certain DVDs
By YoKnows in forum DVD RippingReplies: 1Last Post: 31st Jul 2007, 20:10 -
Sound Issue
By NightFire in forum RestorationReplies: 5Last Post: 26th Jun 2007, 19:15
