  1. I have finally managed to get .q to installed even was able to convert one of my DVDs (but not as I wanted). I cancelled the process and since then the program gives a similar message as this whenever I try to convert anything except certain QT formats. I have already attempted to re-install the complete package
    Encoding started on Mon Jan 3 11:46:18 CET 2005
    ffmpeg version 0.4.9-pre1, build 4736, Copyright (c) 2000-2004 Fabrice Bellard
    configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads
    built on Dec 18 2004 04:39:28, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
    /Volumes/SNAFU/GOOD_BAD_UGLY_16X9_LB/VIDEO_TS: Unknown format
    The DVDs have been ripped with MacTheRipper, the machine is a PB G4, system 10.3.8. I definitely have the all necessary codecs installed. Any clues?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    The ffmpeg engine does not support VIDEO_TS for input. Either make one big all-inclusive VOB or use a different engine.
