    Mar 2003
    Australia
    My friend has an avi file when she opens it in tmpgenc no audio is selected...i have put this same file on my computer and opened it with the same version of tmpgenc and the audio comes up and it converts fine....
    could someone please help..there is something obviously missing off her computer..i have checked the codecs and gspot says she has the right ones installed.
    Thanks In Advance
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Notihng instantly springs to mind
    Perhaps you could post the GSpot screen dump here anyway ?
    If in doubt, Google it.
    Australia
    It could turn out to be the order of the VFAPI plugins.
    You may have to experiment with changing the order of the OpenDML, AVI, and DirectShow readers to get it to read correctly.
  4. Member daamon's Avatar
    Melbourne, Oz
    Does her TMPGEnc default to one of the "Video only" options? Just a guess...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Mar 2003
    Australia
    Thanks everyone for your time and effort...she gave up and ended up using a program called winmpeg...i have never heard of the prog before but it is working for her and thats all that matters
    thanks fellow aussies
