Is their any applications that I can use to scan and "fix" any arrors in the vob files i have made...
I have a bunch of Vobs, If I use autoGK to turn them into a avi file then the app errors saying that it couldn't identify the audio track.
Thing is if I demux and then rebuild the vob auoGK works fine.. I have a number of vobs in this project and would really like some kind of application that can demux and then remux in a batch or a simple scan/fix application for vobs
Is there anything like that around?
Hello,
Well all I know that fixes bad frames is virtualdubmod. It accepts vobs but outputs to avi. Not what you want though.
Check the tools section under "LISTS" on the left of the screen. There MAY be a batch tool for you there
Good luck
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Scan and Fix a DVD that has some errors
By ppeterr in forum Authoring (DVD)Replies: 5Last Post: 21st Apr 2010, 03:38 -
how do I fix an incomplete vob download?
By NotHarry in forum Newbie / General discussionsReplies: 3Last Post: 30th Nov 2008, 12:43 -
Tool to scan and repair vob/ifos?
By milkydoo in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2008, 18:21 -
fix vob
By forare in forum Newbie / General discussionsReplies: 1Last Post: 5th Mar 2008, 05:33 -
Is there an application to fix mov files
By crookedsmile in forum EditingReplies: 5Last Post: 27th Nov 2007, 05:48
