I've downloaded approximately 100 streaming video files from various websites across the 'net, and I'm trying to convert them to VCD so I can view them on my standalone DVD player. Here's some more details before I get to the specifics of my problem:
1. All files are ASF extension. The video codec used is WMV8. The audio codec used is WMV9.
2. I recorded these streaming files using Windows Media Recorder. I've tried using ASF Recorder and I couldn't get that to work.
Okay, so here's my problem. On some of the videos, TMPEGEnc locks up (gives no error message) when converting. If a crash happens, it always happens at the same frame of the video. Here is a list of things I've tried:
1. Loading the file normally into TMPGEnc and converting to VCD. crashes
2. Loading the file normally into TMPGEnc and converting to AVI. still crashes
3. Frameserving the video to TMPGEnc using SonicFoundry Vegas and PluginPac frameserver. still crashes
4. Re-downloading the video from the source website. still crashes at same exact frame
5. Basic repair of the video using ASF Tools. still crashes
6. Advanced repair ("fix bad spots" preset) of the video using ASF Tools. ASF Tools returns error "unknown padding flag: 40"
7. Converting to AVI using ASF Tools. ASF Tools gives warning "file used WMV2 method for video compression. therefore the resulting AVI will not display video"
The only other thing I can think of is to try using a different encoder (either an MPEG encoder or a go-between to a different file format) but I don't know of any others off the top of my head.
If anyone can recommend a good encoder, or any other possible solutions, I would be most apreciative. Thanks much![/list]
I converted wmv and asf to (DivX/MP3) using STOIK Video Converter version 1. I haven't try the version 2 yet. Its a freeware.
http://www.stoik.com/products/svc -
Originally Posted by wincrt
Try ASFTools . It has a number of repair functions.
Also, VirtualDub 1.3 will open ASF files. -
Originally Posted by leglessmoof
Originally Posted by Soopafresh
I tried VirtualDub 1.3 and it wouldn't open the file. The exact error was "ASF: parse error -- too many segments in packet at 1a40 (1 expected) packet size = 79fk, send time 0:01"
Codec problem in ASF/wmv file (wvc1)
By ezzeee1 in forum EditingReplies: 7Last Post: 25th Feb 2011, 20:16 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 15:37 -
Problem Converting WMV
By nepgunes in forum MacReplies: 2Last Post: 16th Jan 2008, 12:30 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 06:16 -
Problem converting ASF to AVI/MP4
By yohu123 in forum Video ConversionReplies: 11Last Post: 16th Sep 2007, 12:24
