I currently have a Dazzle DVC-80. Im wanting to capture video that is larger than 352x240. At first i thought it was my old computer not letting me because it was slow and junky. I've recently just got a new gateway that is P4, 1.0GB of ram and a 160gb hard drive. But even now when i still try to capture higher than 352x240 is Pinnacle Studio it just resets it back to those numbers. I've even tried other programs like Virtual VCR and when i change it to anything higher than 352x240 i get the error message "Cannot set video format: E_Fail 8000405". I've even tried using vdub and get the same error saying it cannot set the video format. I've talked to other people that have the same exact capture device and are able to cap at larger resolutions, but for some reason i can't figure this problem out. Even other people can get the device to show up in Photoshop so they can cap images from it. Anybody out there know what my problem is?
There is no problem,the dvc-80 can only cap up to 352x240/288 and thats it.Hardware limitation.Cheap and nasty capture device you should replace.
Yup
I cant think of why 3 years ago i paid 350$ for this thing
,You shoud upgrade,maybe a capture card.
Oh man that sucks. Weird how on the box it says it can go up to 720x480 and ive seen other peopls vids who have capped it that big. What would you guys recomend for a new better capture device. I plan on using it to transfer VHS to dvd. Also im not looking to spend to much money for it. thanks
If you want to go on the cheap but "Good" try a ATI card,you can get them on ebay anywhere from 30$ to 400$.
Oops this is not the one i had but,you still cant capture Larger,take alook here www.pinnaclesys.com/docloader_n.asp?templ=10&doclink=/WebVideo/digitalvideocreator120/English(UK)/doc/comparisonchart_uk.htm&Product_ID=1427&Langue_ID=2 &loc=chart&division_id=
u may be thinking of the dazzle dvc 150 which does 720x480. that's what i use currently. great quality recordings. i had to throw out 150 bucks for it but i think its worth itOriginally Posted by bizkit54237
Two Quick Questions about Dazzle DVC 100
By Derangedyeti in forum Capturing and VCRReplies: 17Last Post: 23rd Dec 2010, 23:46 -
By Derangedyeti in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2010, 23:04 -
Pinnacle Dazzle 'DVC 170' Woahs...
By synthecypher in forum Capturing and VCRReplies: 4Last Post: 3rd Jun 2010, 22:02 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18
