Have a Canon S70 digital camera that I shot a short clip with and would like to trim a couple of seconds off each end. It's an AVI file but Premiere 6.5 wouldn't open it saying that it didn't understand the compression format. I tried the Canon software that came with the camera but it can't seem to trim.
What's the quickest and dirtiest way to trim this type of clip?
Results 1 to 18 of 18
-Shimon
Originally Posted by shimonmor
I can trim the AVI with DVD Movie Factory.
I didn't transfer the file through the camera.
I used a card reader.
_______________ -
I transfered it via the card reader too. Does that make a difference?
I don't have the program you mentioned though.-Shimon -
Hmmmmmmm.........
After I transfered the file via the card reader I dragged
the file from the removable to my hard drive.
It wasn't called an AVI........just a video file.
I was able to open it up as with any other AVI file.
If Movie Factory can open it, other video apps should
open it too.
When I get a chance I'll try another app. Then I'll edit
this post with the results.
EDIT 1..............
Arcsoft ShowBiz opens and plays it.
Sonic VideoFactory 2 opens it but only plays the audio.
I'll keep trying.
EDIT 2..............
Pinnacle Studio 8.3 opens and plays it.
If you bought a retail version of your DVD burner a copy of
DVD Movie Factory was probably included (with Pioneer).
EDIT 3............
Try Honestech. They have a lot of video programs.
I think they have a free trial.
I tried some of their programs, but I didn't purchase them
because I didn't need them.
I really wish I could help you more.
____________ -
Originally Posted by Goober5744E
Originally Posted by 44echo
____________ -
Who said no?????????
I just did it!!!
I'm using version 1.
Can I go to sleep now???
______________ -
Well I used Quicktime to do it and it worked well...quick and easy. I also tried MS Moviemaker and that worked. I wonder why Premiere 6.5 has a problem with it?
-Shimon -
One of the reasons I bought the Canon S1 was for
the movie mode. I tried some brief clips and I
like the camera a lot!
(I'm using a 1gb card)
(I don't have Premiere)
Good luck.
_________________ -
Originally Posted by canadateck
In version 1 I would save (make movie) as an AVI.
(If you can find a copy of version 1 you will need the audio patch)
EDIT...........
I'll try version 2 or 3 to see if there is a work-around.
_____________________ -
When you have your movie in the timeline, click SHARE at
the top right.
Next, click CREATE VIDEO FILE at the top left side of the screen.
Next, in the drop-down box, save-as an AVI.
I didn't actually save a file, but only went through the motions.
By the way, you have to be in the Edit Video mode.
I cant see thoses Options maybe because, I have DVD MovieFactory Studio Suite , I trust that you can, this is nice to know.
@shimonmor Sorry, I spoke to fast. -
start the program then we have the same program.
The Edit Video button is on the right side of the screen.
That will get you into the editing mode.
(The program won't start if the screen resolution is too low)
_________________ -
VirtualDub opens the file!
Yippeee!!! :P :P :P
Have fun!
(but the Canon file seems to be an AVI)
I needed a plug-in for VideoFactory for mpegs.
Maybe somebody has an answer.
_______________ -
Trim with Virtual Dub and then and effects,titles, etc. in a Video Maker like VideoStudio 8.0, which will convert it to a DVD acceptable mpg.
AVI Trim
By drgt in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2010, 04:36 -
.avi trim and save in original file
By AmyM123 in forum Newbie / General discussionsReplies: 4Last Post: 24th Feb 2010, 14:21 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 01:09 -
What should I do with these digicam AVI files? Batch to WMVs?
By bengance in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 02:16 -
Just Want To Trim an AVI File, Nothing Fancy...
By tangeyj in forum Newbie / General discussionsReplies: 8Last Post: 31st May 2007, 18:08
