In the last couple of days I have had many problems setting up my capture settings.
All was well when I finally stopped bad audio sync troubles. Then, I noticed that on dark areas of the cap there is darker patches.
http://img20.exs.cx/img20/3133/patches7kr.jpg
As you can see on the man's jacket. Would this be something to do with colour/contrast as it's only just started to happen since I installed Btwincap drivers for my card. I am using VirtualVCR to capture.
Thanks in advance
-Nick
Hi stixster,
It'd help if you said what format you were capturing to and what your settings are...
Also, check out lordsmurf's site: www.digitalfaq.coom - he's big on capturing and capture cards etc.
There's also Capmaster - maybe PM him and point him to this thread...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Sure thing.
I'm capturing at 720x576 Res with Picvideo MJPEG at 19 qty.
Then using to VDub to crop noise of edges and de-interlacing/resizing to 640x480.
DivX at 1300K
-Nick
SD Panny Plasma Quality worry
By MAC007 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Jan 2011, 15:08 -
Do I need to worry about MOV files launching browser windows?
By tonyp2 in forum Software PlayingReplies: 4Last Post: 19th Sep 2010, 11:46 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
Encoding in Virtualdub: Do you have to worry about frame rates?
By FallenAngelII in forum Newbie / General discussionsReplies: 28Last Post: 7th May 2007, 12:15
