I am attempting to use VirtualDub-MPEG2 v1.5.1 to tweak some clips I have captured (via WinDV) from VHS tape by means of a Canopus ADVD-100 box. When I try to load the clip into VirtualDub it complains that it "couldn't locate decompressor for format 'dvsd' (unknown)" .... VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
Fair enough, I ran the clip through GSpot v2.2.1, and it claimed I had two compatible codecs installed - DV Video Decoder and AVI Draw. It also successfully "Rendered" the clips.
I tried adding each of these as String vales in the registry into HKLM/.../WindowsNT/Current Version/Drivers32 as key "vidc.dvsd". This did nothing for me. Am I missing something obvious?
The clips incidentally play fine in a variety of players, but I particularly want to try out VirtualDub since I haven't too much experience with it other than the occasional format conversion.
Incidentally, why does WinDV split the recording into chunks? I get typically 3 or 4 clips in a one hour capture.
System: XP sp2, P4, ABIT AI7 mobo, 1GB RAM
bot
Install the free and very good Panasonic DV Codec - works well with VirtualDub of any flavour...
As for the chunks in WinDV:
1. Set the discontinuity threshold to 0 - this ignores each new clip that's been recorded. 1 means "new AVI for every new clip filmed".
2. Increase the Max AVI size (frames) to XXX.
You can calculate XXX to whatever you want it to be - There are 25 frames per second for PAL, 30 for NTSC. That's 60 x 25 or 30 per minute, 3600 x 25 or 30 per hour.
Based on that, put in an appropriate value. I use 100,000 - just over an hour.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thank you both, very informative and helpful as usual! Everything now works a treat.
bot
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 05:14 -
A few questions about bitrate,codecs and virtualdub
By alibaba12 in forum Newbie / General discussionsReplies: 21Last Post: 5th Jan 2012, 17:30 -
Codecs for WMM | WMP | VirtualDub
By TheGame111 in forum EditingReplies: 1Last Post: 22nd Dec 2010, 17:42 -
Codecs in VirtualDub
By TDT_99 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2007, 10:52 -
what is the best codecs to use in virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 9th Jun 2007, 07:16
